Problem fitting Ashtray Delete- HELP!
karbonk Dec 16, 2009
  1. karbonk
    karbonk Living a little!
    182
    As Above,
    I ordered the part but seems to be too wide. Am I doing something wrong?
    Its as if it tucks under the side plastic to make flush but cant see there beeing enough room, am I to cut the sides off?
    I have tried getting the side plastic trim off ( triangle handle trim) but cant seem to get it off, I have unbolted the 2x bolts where is the other?
    Thanks in Advance.
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    You need to remove the grab handles mate. You'll find a bolt on each towards the front under the console, a bolt at the rear under the gear stick gaiter and then a bolt at the apex of the handle at the top.
    Once the handles are off the tray pops in and the handles go back on making a nice flush fit.
  3. S24 GMP
    S24 GMP New Member
    You shouldn't need to remove the grab handles, (well i didn't when i fitted mine) the side bit should just push in.
  4. Staz
    6,206
    67
    :blink: no chance! The grab handle overlaps the top of the tray!
  5. karbonk
    182
    Yep had to take the grab handles off screw under console, very very awkward!! Lost the bleeding screw and bit, went down the back and gonna have to take the whole centre console out tomorrow as run out of time and is a bigish job, need the car to get to work at 1pm. :banghead:
    Thanks all, made it so much easier.
  6. 4NT
    4NT Terminal Douche Bag!
    368
    Just a quickie, how much did the part cost? Think I'd like to do this too.
  7. karbonk
    182
    From memory its £9.50 or about. Bargain!
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    indeed it is and grab handles deffo need to come out, its all a bit fiddily but works fine in the end, i love the extra space
  9. 4NT
    368
    Cheers, got a contact there and I can get the rubber dimple tray thing for relatively cheap but they said I need loads of other bits of trim, sent me the full diagram, couldn't figure it out. I only want some place to stash my phone!!!
    What's the verdict, 1 part sub £10 or loads of little bits coming to +£50??
    Cheers.
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you only need the one bit the othe bits are for the cig tray.
  11. karbonk
    182
    All you need is the 1 Part. Part Number is on here somewhere.
  12. aristides
    aristides Member
    550
    Does anyone got the part number for this small trim? I would like to do the ashtray delete myself, since i`m not smoking -at least in the car :)- and i need a place to put my junk!!
  13. jameo84
    jameo84 Member
    122
    id also like the part no. thanks.
  14. Khufu
    Khufu Well-Known Member
    5,704
    31
    its 8P0 863 301 A 4PK for black and if you unlucky enought 8P0 863 301 A 6G6 for blue...
  15. jameo84
    jameo84 Member
    122
    were is best to get one from? stoke audi?
  16. Khufu
    5,704
    31
    East kilbride? Not too far from me. You could get 10% of at Stoke IIRC being a sponsorer but by the time you factor in delivery on something circ £10 it might be worth a visit to your local dealer - the other half can visit Braehead while your there LOL
  17. jameo84
    jameo84 Member
    122
    cool i just pop in the next time im out that way. thanks
  18. geraint.davies
    geraint.davies Member
    47
    If this is fitted with the brushed silver trim, is the tray still black?
    Sorry if this is a silly question!
  19. NHN
    29,523
    1,766
    The other parts would be the trims that go above the rubber storage part, that fix to the underside of the climate control, there's a trim or 2 & also they tend to have the led strip that goes under there aswell to light the area up if you have the interior light pack, you dont need this lot, but I personally think it finished it all of nicely & those handles 100% have to come out to fit incase you are thinking of a quick fix. :)
  20. NHN
    29,523
    1,766
    Well if you think a silver tray looks good then I'll supply & spray it for yer, (nottttt), lol, nah mate the rubberish tray is black. :)
  21. aristides
    aristides Member
    550
    NHN do we have also these parts? I mean the led stripe that is fixed under the climate unit. It would be nice to complete the interior light pack, since i already did the doors and the map lights.
    A while ago i found a guide in a german forum , but i cant seem to locate it again!
  22. geraint.davies
    47
    Resurrecting an pld thread, having the same problem, don't seem to be able to find/undo the third bolt on the grab handle, have undone the one by the gearstick and the torq one at the apex of the handle, just can't get to where the third will be, what trim needs removing?
    Any help much appreciated as the car is currently in bits!
  23. PH1L
    PH1L Gievf Buckets
    3,851
    40
    theres one on the underside of the grab handle mate
  24. geraint.davies
    47
    Its ok, sorted it now.
  25. geraint.davies
    47
    Didn't see this, was outside, managed to work out it out.
    Cheers anyway.
