Problem after my 5000S 5cyl. warms up
c_coffell64 Dec 19, 2003
  1. c_coffell64
    c_coffell64 New Member
    21
    The problem is that after it warms up, it wont start again.Until it cools down after a while.I was wondering if anyone had that problem before and if anyone knew a solution to it.
  2. Mutley
    Mutley Member
    67
    Hi Cannon,
    Does your car use Bosch k-Jetronic fuel injection? I had a Mk2 16V Golf with a similar problem some years ago. Try the following:
    1. Locate the fuel distribution / metering device (it will have reinforced hoses going to the injectors, and when your car won't start, give the device a sharp tap in the top-centre. The metering piston is directly below this casting and mine used to stick in the down position when hot therefore not allowing any fuel to be injected. A sharp tap would usually free it up. If this fails, take the air intake cover off and move the circular disk up and down several times. This should move very smoothly - any stickiness indicates a problem with the piston bore and the unit will need replacing.
    The use of a good fuel injector cleaning solution will help keep this free.
    2. Another possibility is the cold-start regulator. This is bolted to the engine block and, depending on temperature, varies fuel pressure to the top of the piston I mentioned in (1) above. Unbolt it thereby letting it cool down when you have the problem and see the engine starts. Don't leave it un-bolted though becuase your engine will run rich.
    all the best
    Jon
    /ubbthreads/images/graemlins/beerchug.gif
  3. c_coffell64
    21
    Well, thanks for the help. I will tell you what happens later when I do that. But I also think i have to get some new sensors for it. They are caroded a litle bit. And I think that one of the sensors is for the water temp. wich my temp gauge isn't working right now, and there is some other sensors I also think they are for the cold start up and something else that deals with the temp.
