PRNDS flashing
les hook Jul 7, 2010
  1. les hook
    les hook New Member
    The PRNDS indicator on the display has started to flash every few days, usually leaving the car switched of for a while stops it flashing, my car is a 2004 Avant 1.9 Diesel Multitronic, with 118000 on the clock.
    Is it a big job to cure and if so is there anywhere in Leeds that I could get it fixed, preferably not an Audi main dealer.
    Les
  2. quattrojames
    14,050
    576
    From memory it's the gearbox ECU on the way out - not a cheap fix iirc. Sorry I can't be more specific, try a search on here.
  3. SirSpanky
    SirSpanky New Member
    Have to agree with quattrojames, time to find a good garage to check it out...
    If you're brave, you can order a refurb unit from someone like this:
    http://www.bba-reman.com/catalogue/Products.aspx?category=816
    and they'll knock £150 for sending your old one to them.
    All you need to do is unclip it and slide it off (carefully, as the plastic guides are a bit fragile) and put the new one on. There's a guide for doing it somewhere, but i couldn't find it just now... I'm fairly sure there is no coding to be done (but i have been known to be wrong).
    If you go to a garage, make sure you get the oil on the gearbox changed as well.
    Welcome to the (often expensive) multitronic owner's club!:)
  4. NHN
    29,332
    1,716
    Check the microswitch that is built into the gear unit below gearstick, basically its the switch that signals when its in park & unlocks the key for removal, mine was dodgy on the A3 SB & I messed with it a bit with a finger & hasnt done it since.
  5. blackpool1974
    blackpool1974 Member VCDS Map User
    138
  6. Just had my multitronic ecu changed . Had the ecu recon by ecutesting and the work done by www.nass-techautos.co.uk ,vw and audi specialist, in the end all done for under£700 ... the car now drive sweet
  7. V8Guzzler
    V8Guzzler Active Member
    583
    26
    Hello, hope you don't mind bumping this thread. Mine just did this today, however it had no effect on the drive. It selected gear changed gear all faultlessly. Would a fault code show up on a scan?
  8. TheBlackScarface
    TheBlackScarface No Ego
    344
    49
    This is exactly what happened to me on Bank Holiday Friday. Take a look at my thread it should be able to help you.
  9. TheBlackScarface
    344
    49
    What happened to your car in the end did you resolve the problem?
  10. V8Guzzler
    583
    26
    Not had chance to look at it yet. Still works fine and hasn't flashed for a few days. I need to clean the contacts first... But I need to know how to locate it.. Any ideas?
  11. V8Guzzler
    583
    26
    Hi mate
    How do I find this switch? And where is the ecu and how do you get to it?
  12. TheBlackScarface
    344
    49
    Hey mate im not a specialist but i do know the ECU chip is located somewhere in the gearbox well that's what my mechanic told me (Lol).
  13. V8Guzzler
    583
    26
    Got a mate who is going to take a look if the worst comes to the worst ecu testing will repair for £250, plus a couple o hours labour for my mate to remove and replace £350 or so not too bad I guess :)
    It's ok at the moment touch wood
  14. ianh
    ianh Member
    62
    plus oil,£70 or so
  15. V8Guzzler
    583
    26
    Chuff, forgot about that! What stuff do I need?
  16. V8Guzzler
    583
    26
    Hasn't done this for days now... I'm guessing it will pop up again soon though
  17. E4
    E4 2004 A4 3.0 V6 Cabriolet
    15
    Mine has started flashing today :( is it ok to drive until I can get to a specialist? Or am I making it worse ?? 3.0 v6 petrol
  18. V8Guzzler
    583
    26
    I spoke too soon... Went to brum today and was flashing all the way there. Drives fine although Sport will not work. I pulled over turned off the engine, then back on.. No flashing. Been fine for the rest of the day. Mines been flashing on and off for a week or so now and still drives fine. I am thinking it's a bad contact / switch than the ecu on mine.. In on Tuesday for cam belt service and I have asked them to check gearbox contacts etc.. So we wait and see
  19. E4
    15
    Hoping it's an electrical gremlin too
  20. V8Guzzler
    583
    26
    Just ran a scan on mine... (did it twice)
    Monday,09,May,2011,18:34:38:26365
    VCDS Version: Release 805.1
    Address 02: Auto Trans
    Control Module Part Number: 8E0 910 155
    Component and/or Version: V30 01J 3.0l 5V RdW 3120
    Software Coding: 0000001
    Work Shop Code: WSC 04926
    1 Fault Found
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 000 - -
    Freeze Frame
    RPM: 1536 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 13.0
    Torque: 0.0 Nm
    Temperature: 47.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0001 0 1
    Monday,09,May,2011,18:36:15:26365
    1 Fault Found
    P0706 - 000 - -
    Freeze Frame
    RPM: 96 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 1.0
    Torque: 244.0 Nm
    Temperature: 46.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0001 0 0
    Ross-tech Wiki...
    Possible Causes
    Failed Multi-Function Transmission Range Switch (F125)
    Wiring harness issue between F125 and TCM
    Failed TCM
    Possible Solutions
    Inspect wiring harness between F125 and TCM, repair as needed
    Replace Multi-Function Transmission Range Switch (F125)
    Replace TCM
    The question is - could this just be a simple wiring fault? If so where would I start?
    Help appreciated :)
  21. Iyole
    Iyole N/A Rools
    69
    I've had the same problem the last 6 weeks.....Intermitent.......and drives fine when flashing but.
    I'm thinking contact below Gear Lever....which I was unaware of....
  22. V8Guzzler
    583
    26
  23. V8Guzzler
    583
    26
  24. tariqonnet
    tariqonnet tariqonnet
    I'm having this problem since 6 months now, it usually comes when I start the car and the temperature of my car is in between 0-90 i.e. engine has not reached its optimum temperature. for eg. I drove the car for a while and then park it for about 10-15 min. and try to start again. and when the car is heated up, I move it to "P" and the flashing is gone. If I take care of this (letting the car cool down before I restart) then this problem doesn't come for weeks. I do not feel any power loss as such during the problem.
    I'm not sure about living with this problem, may be I'm killing the gearbox gradually?
    any suggestions.
  25. bad8008
    bad8008 entry level???? :)
    PRNDS flashing, isn't that limp mode.
    Happened to my wives B7 A4 Avant. I swapped the 317 Relay from the ECU box to the lower compartment, now its the intermittent engine start unless I fiddle with the swapped ECU at the lower compartment. No more PRNDS flashing, so confirm its the ECU Relay.
  26. Micki
    Micki New Member
    I've had this problem for a while on my vehicle and I've just found out what the problem is. I came across a website called ECU Testing and they describe the exact symptoms of my car. I phoned a local place called Regal who do ECU testing and it is definately much cheaper than going through Audi dealership.
  27. V8Guzzler
    583
    26
  28. frankies_s4b7
    frankies_s4b7 New Member
    Hi there!!
    I have an audi s4 b7 4.2 v8, the last week the car has shown PRNDS on the dash display.
    its not flashing, just stays on. happens when its a warm day.
    before that, I notice the trans tries to select its gear from "d" to 5th gear then 4 then 3 then back to 5 then jumps to PRNDS , stays lit, and drives normal.
    I noticed if I park up hill, it goes back to normal operation driving, with all gears displayed, and then 10 mins later, back to PRNDS.
    Could it be low on oil?
    does any one have any idea?
    thanks
