Price request for following A3 8P parts
sub39h Jul 7, 2010
  1. sub39h
    sub39h Active Member
    2,502
    1. >2008 rear bumper (for cars equipped with rear sensors) for 3dr
    2. new style rear sensors (with all parts needed to retrofit)
    3. facelift LED style rear lights for 3dr
    4. chrome TT vent rings from mk2.
    thanks!
    S.
  2. stoke_audi
    stoke_audi Active Member
    2,243
    19
    bumper cover £194.46
    parking sensor £59.70 each
    cap £2.00 each
    o-ring £0.07 each
    wiring £95.30
    (is your A3 already fitted with parking aid?)
    rear lights £83.02 each
    vents £77.95 each
  3. sub39h
    2,502
    Hi there,
    Thanks for the quick reply. It's fitted with an aftermarket kit, which i was wanting to swap for an actual Audi one. my understanding is that the facelift one will fit on the 8P2 models with a bit of modification. is this correct, or would you suggest reusing the kit that's already fitted?
    cheers again,
    S.
  4. stoke_audi
    2,243
    19
    hi
    can you see any part number on the parking aid control box
    may already be the Audi accessory one fitted
    Dave
  5. sub39h
    2,502
    hi dave.
    i can confirm it's not an Audi accessory part. i'd like to ideally make the rear bumper look as if it came from the factory with sensors, hence why i want to retrofit the official Audi ones that would have come with an MY09 car if it was ordered with PDC. do you know how technically difficult this would be?
    Regards,
    S.
  6. stoke_audi
    2,243
    19
    looking at the rear bumper with factory fitted parking aid.
    it already has the mountings to fit the factory fitted sensors onto it.
    the bumper without the factory fitted sensors cannot have them fitted,
    due to not being able to get the mountings as seperate replacement parts
    so the only option is an Audi accessory kit or aftermarket kit
    Dave
  7. sub39h
    2,502
    hi again. i'm under the impression that if you order the bumper specifically for cars equipped with rear parking sensors then they come drilled and with the mounting rings already attached. if i were to go for this solution would it be possible to retrofit the same sensors that are fitted at the factory?
    cheers again,
    S.
  8. stoke_audi
    2,243
    19
    HI
    the old parking sensors would not fit into the new rear bumper with sensors,
    due to the mounting being different
    Dave
  9. sub39h
    2,502
    i'm trying to equip my car as an '09 car would be equipped from the factory in respect to the rear bumper and sensors.
    i.e. i've found a bumper that will fit, and it's got the factory mounting points for the sensors, but can i buy the '09 sensors and have them fitted? my car doesn't have factory sensors, it has a non-Audi aftermarket kit so my question is basically this:
    can i retrofit '09 rear sensors to an '06 car that wasn't equipped with sensors at all from new?
  10. stoke_audi
    2,243
    19
    Hi
    its not something that we would do ourselves, as we would only fit the Audi accessory ones to an Audi if it come without parking sensors
    Dave
  11. SneakaFreaka83
    SneakaFreaka83 ASN is hazardous 2 your wallet
    348
    Hi Dave,
    Looking to get the s3 metal pedal set to replace my rubber pedals for my 2004 a3 could you give me your best price with shipping please. Thanks
  12. stoke_audi
    2,243
    19
  13. sub39h
    2,502
    Hi Dave,
    How much would a 2010 S-Line front bumper cover (with headlight washers), foglight grilles (but no foglights) and black optics grille cost?
    Also are the foglights from the prefaeclift (8P2) S-Line the same as the ones from the '09 S-Line ones, or are they different?
    (You can see what I've got cooking here, can't you!)
    S.
  14. stoke_audi
    2,243
    19
    to fit the new 2010 front bumper would be costly
    as you would require the following
    bumper
    grill
    bonnet (as the body line is different)
    wings as they do not have side repeaters
    mirrors as they now house the side repeaters
    so before i start would work out quite an expensive job
    Dave
  15. sub39h
    2,502
    ... I know. I'm trying to work out how costly it'll be. It has been done before so I'm relatively undeterred.
    S.
  16. stoke_audi
    2,243
    19
    ok i try and work it all out
    pm me your chassis number
    so i can match upto a new A3 for what you want
    Dave
  17. sub39h
    2,502
    PM sent... prices and part numbers would be most helpful!
  18. sub39h
    2,502
    also could you give me a price for the engine cover for the latest facelift 2.0Ts
    looks like this:
  19. sub39h
    2,502
    any luck yet dave?
  20. stoke_audi
    2,243
    19
    sorry
    not been upto much as been busy sorting out bump i had
    but will catch up, i can use my chassis number to match up for stuff you need
    Dave
  21. sub39h
    2,502
    cheers dude... hope everything's ok!
  22. stoke_audi
    2,243
    19
    ok
    engine cover £36.55
    parts for conversion
    incl bumper,bonnet,wings,headlamps,mirrors,side repeaters £1700.00
    dave
  23. sub39h
    2,502
    Thanks matey. Any chance of a breakdown of the parts needed and the costs individually? I'm trying to work out what I should buy from you and what I can get away with sourcing 2nd hand!
    Thanks again,
    S.
  24. sub39h
    2,502
    bump
  25. stoke_audi
    2,243
    19
    pm me your email and i will send you the list over
    but to be honest dont think you find any 2nd hand parts for this conversion
    Dave
  26. sub39h
    2,502
    cheers matey, but i had actually sourced a whole front end from someone local to me... but someone else grabbed it from right under me!! there's a few front ends going on eBay and the like so hopefully another set will turn up soon!!
  27. sub39h
    2,502
    hi Dave,
    a very Happy New Year to you, and i hope you enjoyed the holiday period. i called Stoke Audi Parts as per your PM and spoke to someone who wasn't massively helpful lol. he said that he couldn't help me with this line of enquiry and to wait until you got back. i sent you a PM explaining as much, just following it up with a msg on here. you have my email, so if you could send me a break down of the part numbers and prices of the items i'd need for a front end conversion i'd be most appreciative
    thanks again
    S.
  28. stoke_audi
    2,243
    19
    pm sent
    Dave
