Pressure Switch Location?????
LordNelson Sep 10, 2009
  1. LordNelson
    LordNelson Member
    167
    Can anyone help my locate the Air-con pressure switch on my S3 8L (2000).
    I might be being stupid but cant locate it.:think:
    I need to test the switch before i go and buy a new one.
    thanks :beerchug:
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    You may have more luck in the 8L forum mate.
  3. mike-turbo
    mike-turbo Member
    109
    its behind the heat sheild at the back of the turbo
  4. technics100
    technics100 Member
    848
    24
    On the A4's the pressure switch is located on the air-con radiator near the pass side headlight, its just a unscrew and change job..
  5. Wobbler
    Wobbler New Member
    Does the system need the gas removing first? My A4 has a blown fuse 6 (air con pressure switch) and blows a new fuse as soon as the ignition is swiched on. I'm thinking that if the wiring is ok (will test for a dead short at the plug when I find the damn switch) then the pressure switch must have died and gone dead short.
  6. Staz
    6,206
    64
    Yes mate if you want to change the pressure switch the whole system needs to be recovered
  7. Wobbler
    Wobbler New Member
    How the hell can you get to the sensor? Please tell me you don't have to remove the front bumper!!
  8. Staz
    6,206
    64
    You may have more luck asking in the A4 forum mate.
  9. technics100
    technics100 Member
    848
    24
    No it doesn't (B6 A4) it just unscrews and unplugs..
  10. NHN
    29,284
    1,695
    Yeah this is where it is I believe, as thats what I had to change on my late 99 S3 once, I lost cold air, so changed this which was £50 & it worked again, its slightly more to the right IIRC from the turbo, but is hidden behind the heat shielding in that area attached to the silver pipes & as already said, they emptied system then regassed to do the job.
  11. Staz
    6,206
    64
    Ok if you do it that way you'll vent all the refrigerant!
  12. NHN
    29,284
    1,695
    I would have to agree, given the name of the actual switch it would suggest its not a good idea to undo it without removing the pressure it reads, given its refridgerant that wouldnt be wise huh Staz.
  13. Staz
    6,206
    64
    ...and illegal!
    Plus it would allow air into the system if it was done that way so it'd have to be deep vacuumed before recharging.
  14. Wobbler
    Wobbler New Member
    I have read that the switch screws into a valve assembly similar to a tyre valve, although this would mean some gas would escape as the valve was removed/fitted.
    Think I'll get the garage to do it for me.
  15. NHN
    29,284
    1,695
    Advisable mate, given the system involved & yes, iirc, it just screws onto the pipe as such.
  16. Staz
    6,206
    64
    Yeah and as the refrigerant escapes it super cools and will give you frostbite.
  17. Wobbler
    Wobbler New Member
    Sooo. gloves would be advisable then?.......just kidding, given that the bumper has to come off and that I have no inclination to undertake a job I'm unsure of, I'm gonna book it into the dealers.
  18. NHN
    29,284
    1,695
    Why take it to a dealer mate, take it to any garage that has an ac gasser, they can remove the bumper & re-gas for a hell of alot cheaper than audi for sure.
  19. technics100
    technics100 Member
    848
    24
    Changing the G65 pressure switch does not vent the system. I have changed the sensor, it just unscrews and the new one screws in.
  20. Staz
    6,206
    64
    How does it keep the refrigerant in then?
