pressure release sound from engine bay when engine is stopped
karlabdool Dec 24, 2013
  1. karlabdool
    karlabdool Member
    150
    19
    hi all,
    i have the fwd 1.8tfsi, 4700kms
    does anyone hear a sort of hissing (pressure release) sound that pulses (hisss stop hiss stop etc.) when they switch off their engine when returning home from a trip with the car?? the sound only lasts a couple of seconds .
    I am not sure if it is venting pressure from the turbo that might still be spinning slowly ( i do give a minute or 2 spool down time before i switch off)
    i also noticed a very very mild oil stain on the plastic shield right below the oil fill cap. The cap seems to be spring loaded as well. I hope i do not have some kinda back pressure problem.
    car doesnt seem to be burning any considerable amt of oil either.
    Car drives fine tho.
    any ideas?
  2. driver_tim
    driver_tim Active Member Team Daytona Audi A3
    317
    I have the same engine. Not noticed a hiss but will keep my ears open.
    I also have a small oil stain near to the filler cap. I check the oil level regularly and it doesn't seem to be burning much if any. I put the stain down to the dealer topping up the oil during the PDI.
  3. karlabdool
    karlabdool Member
    150
    19
    Yea I think the oil was a bit overfilled and maybe some vapor came out when I did some red lining ? Who knows ? I read somewhere that the pulsing hissing could be a/c so I will have to drive without a/c and see. The hiss does seem to come from lower left area of engine bay
    Thanks for your response Tim
  4. karlabdool
    karlabdool Member
    150
    19
    Lower left as in passenger side
  5. Dan_G
    Dan_G Active Member Team Navarra Audi S3
    237
    142
    43
    Air con compressor.
  6. karlabdool
    karlabdool Member
    150
    19
    Could very well be a/c, btw how much kms have you done so far Tim?
  7. driver_tim
    317
    3100ish, not had much chance to use the car since I got it at the beginning of September unfortunately.
  8. karlabdool
    karlabdool Member
    150
    19
    Ok well it did lose some oil since last I checked. The level is a bit lower than half at the current mileage of 4700 kms . I'm monitoring it carefully and bought some top up oil incase it gets too low b4 5000 kms ( service)
