Pre to face boot lid swap
floyd 1.8 turbo Jan 15, 2010
  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Will a facelift bootlid directly fit onto my pre? I know it will fit but are bolt holes in correct place and are wiring plugs the same?
    Can this be a straight swap??
    TA!
  2. Geeman
    Geeman Low Life
    1,318
    The one you're after (mine) doesn't have the in-boot wiring loom with it - you'd need to use your existing loom... as it attaches to the main car loom. Not sure how the pre-facelift wiring works, but I'd guess that it's not a completely straight forward job.
    All the connectors are there and working... just need to see if anyone here knows what's involved with the swap-over.
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    14
    pre facelift uses air line for locking system facelift is electric so its not a straight swap
  4. aragorn
    18,444
    848
    The pre-facelift cars have a mechanical pop, with a normal locking mechanism on it, run from the CL pump, like the door locks.
    Facelift cars dont "lock" they just have an electronic solenoid that opens the bootlid, and a pair of microswitches on the lid to activate the solenoid when the car is unlocked.
    You'd need a facelift central locking pump and associated loom, if you wanted to fit a facelift tailgate.
  5. Padz
    Padz Member
    51
    Sorry to butt in here but will the facelift tails fit pre-face cars without modification?
  6. Foxmeister
    Foxmeister Fired Up!
    1,785
    The units will swap over mate, but there is a pin swap on the plugs thats needed as the reverse light has changed position. Simple procedure, just fiddly!!!:keule:
  7. Padz
    Padz Member
    51
    Thanks Foxmeister - you saved the day again!! I think my mechanic will be up to that. Cheers again pal :)
  8. floyd 1.8 turbo
    632
    Ok thanks all, sounds like it may be quite a mission so as i dont really have the time i think i'll pass, already got enough to do so shouldn't really get involved!! Thanks for the help though chaps
  9. mixmaster
    mixmaster Member
    86
    Sorry to reopen this thread but I just wondered if anyone had any more luck or information on swapping a Facelift tailgate onto a Pre Facelift A4 B5.
    I have a '98 Avant.
    Thanks in advance.
  10. aragorn
    18,444
    848
    Read my post above.
  11. mixmaster
    mixmaster Member
    86
    Thanks aragorn.
    So it's as easy as a facelift pump and rear loom? Would you know if the boot release is controlled by the pump?
    I guess I will need a 3 button key reprogrammed with a boot release?
  12. aragorn
    18,444
    848
    You'd need to find the wiring diagram (look on ebay for elsawin) for PFL and FL pumps and see whats involved. If theres enough similarity you might get away with simply adding pins to your existing harness, but if the harness is majorly different you'll be having a big headache unless your good with wiring.
    The boot release is controlled by the pump. The "open" buttons goto the pump, and if the pump is happy that the boot should be opened (ie the car is unlocked) the pump fires the solenoid.
    You'll need a 3 button fob most likely yes, but you may find your existing two button fob will work ok.
  13. mixmaster
    mixmaster Member
    86
    The pump I have is 8L0 862 257 H.
    RCL is not a factory fitted one.
    I guess this isn't as straightforward as it seems due to the lack of information so thanks for any pointers in the right direction.
  14. LeeT
    LeeT Member
    429
    Ive decided to go ahead and try and fit the facelift tailgate whilst im doing the rs4 widebody. Are all these posts related to getting the tailgate to open on the central locking? ie, if i fitted it as is would the tailgate unlock just by using the key? I might look into possibly making the pfl locking system fit the facelift but ill have to take a closer look. Ive got the internal wiring for the facelift tailgate.
