Prawn and BigAls A3 Track Car
Prawn Dec 29, 2010
  1. Prawn
    11,418
    3,306
    Cheers RST, I've not written up a spec list for the car for a very long time, as it's just too long!
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    Over 2000 posts wahoo lol ;)
  3. Prawn
    11,418
    3,306
    woohoooooooooooooo!!!!!!!!!!
    That's a scary number of posts all about my million mile 14 year old FWD hatch back :p
  4. Prawn
    11,418
    3,306
    Finally!
    I have rods, I have a low mileage agu for the build, things can get started!
    Danman1 likes this.
  5. Paradox1
    Paradox1 Active Member
    1,833
    88
    Woooo,you don't mess about!
  6. StaceyS3
    2,489
    473
    Bet you cant wait to get all that in and turn the boost up :racer:
  7. Prawn
    11,418
    3,306
    can't WAIT stacey! Sadly, I refuse to rush and bodge it though, so I'll be having the head done properly by Bill with new supertech valves and guides, and that's not cheap at all!
    Then I'll clean up the block and have it honed, new rings, and probably main bearings as well as the bigends I got with the kit.
    Whilst it's out I'll hve my diff fitted into another box as well, as this noisey first gear terrifies me!
  8. moredoor
    moredoor Member
    160
    Yes rods:icon_thumright: do I also see head studs Mr P?
  9. Prawn
    11,418
    3,306
    Whole kit man :) just need the head done, nnew rings, and an oil pump an we can get building!
    Did the best mod to date today....
    Colour coded air freshener!!!!
  10. Paradox1
    1,833
    88
    Thats soo Gangsta
  11. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Have you got a gear box yet? And do you still have that k04 adapter ring for the tip?
  12. Prawn
    11,418
    3,306
    UYes to both Dan :)
    Text me :)
  13. Neru
    Neru Member
    129
    9
    What gearbox are you planning on? And how much power are you expecting
  14. Prawn
    11,418
    3,306
    I've got a new low mileage 02J box neru, I'll rebuild that and put my Quaife ATB in it, so the same as the current box really.
    Power wise the plan is to settle on 330bhp, but it'd be nice to do a few runs to see what it can do, and see if it can equal Wellys 344bhp on this turbo :)
  15. Prawn
    11,418
    3,306
    Grrrrr....!!
    Subframe is moving again.
    Only under extreme conditions, hitting bbumps under WOT in 2nd here it wheel hops, and braking over rough sections of road where it jars the car a bit. Can hear the ssubframe moving and feel it through your feet as well!
    Anyone got any info on solid subframe mounts?
  16. HTC
    HTC Active Member
    3,428
    9
    Do you have TT mounts fitted?
  17. Prawn
    11,418
    3,306
    I don't Kev, no. What might these be?
    I do vaguely recall TT subframes having extra mounting points at the back?
  18. HTC
    HTC Active Member
    3,428
    9
    They come in 2 parts per side and are tougher than the standard items. Part numbers in the pictures.
  19. HTC
    HTC Active Member
    3,428
    9
    I also remember some of the yanks building all sorts of braces for the subframe on vwvortex.com. You could search over there for info.
  20. Jason.s
    Jason.s Active Member
    2,879
    348
    The TT convertible has 2 braces on the subframe but that subframe is only fitted to the convertible. The bushes are the same as the R32/S3/TT/Beetle RSI too.
  21. Prawn
    11,418
    3,306
    Cheers for the advice chaps. I think I'll go for some solid bushes rather than uprated TT ones though.
    I tried to tighten the subby up this morning, and the bolts are all already FT, yet it's still moving around, so solid bushes and new bolts seem like the answer.
    Anyone got any details for solid bushes from anywhere in the UK? could do with some ASAP!
    Federal RS-R's are now below the limit for road use, so I swapped back onto the SuperT's this morning and gave her a clean again :)
  22. Gops
    3,197
    666
    Looks nice and mean that does mate! Love to see this monster in action!
  23. Dani_B19
    9,113
    346
    Nick email hektor off he, he runs wot motorsport and sorted me out with sum 034 solid sub bushes, i bort the bolts aswell for less then £20 and they are sooo gud, you cant really tell when driving straight or normal but when booting it or cornering hard you can tell they are their.
    HEKTOR likes this.
  24. Prawn
    11,418
    3,306
    Already on it Dani (Y) I remembered you mentioned them, so searched and found the thread :)
    Just need to sort out some payment details and the mounts will be on their way to me :)
    Whilst I'm at it, I'm also going to fit some poly castor correction bushes to the wishbones to sharpen up the handling a tad, and I noticed a tiny bit of play in a track rod end this morning when spanner checking things, so I'll replace the lot, bushes, subframe mounts, ball joints, and track rods and ends, and then have the alignment done :)
  25. Dani_B19
    9,113
    346
    Haha gurd. Do you need the subframe bolt part numbers as they seem to have revised the part numbers? Also what you doing abot top mounts? Im undecided on weva or not to follow stacey or just buy solid ally ones!
  26. Dani_B19
    9,113
    346
    Also if your rebushing the wishbone email andrew and get a set of defcon style inserts and but some 30mm poly bushes, indropped a ball as i had the ultra rare 30mm wishbones but thougt i may as well fit the new bushed wishbones had and sold my old ones for £200 lol.
  27. Prawn
    11,418
    3,306
    I'll be getting the ground control top mounts like stacey when funds permit mate.
    Does andrew make the defon style inserts with an offset hole for castor correction then? do you just buy the 30mm bushes from a normal supplier?
    You seem to be a bit further down this road than me, so if you could PM me any details I'd be hugely grateful!
  28. Dani_B19
    9,113
    346
    Do the defcon bush go into the normal 45mm gole to reduce it to 30mm, im unsure if the poly bushes will work with them, can you buy them in 30mm size? If aothey should work just the same as normal 45mm bushes!
    Haha my suspension setup is like a shopping list, its the most setup s3 i know lol.
    Im thinking about the ground control top mounta to tey and combat me destroying top mounts as the lcr ones ive got seem to have died after 8 momths of abuse and pot holed roads.
  29. Prawn
    11,418
    3,306
    What I'm keen to know about Andrews inserts, is if the 30mm bush hole for mk1 TT bushes is central or offset.
    If it's central, then it'll tighten things up but not alter geo at all.
    if it's offset, it can be placed to increase CASTOR, which is the main advantage :)
  30. superkarl
    superkarl MAN OF STEEL
    9,406
    2,379
    if you want to increase the camber you can increase the size of the slots on the wishbones so that the ball joints have more adjustability.
    unless you can find some 30mm offset bushes, you'l have to make do with central ones. the defcon inserts litterally just make the hole smaller, so you can fill them with whatever 30mm bush you want or require.
  31. Prawn
    11,418
    3,306
    nooooooooooooooooooo. Defcon inserts are definitely offset! that's the whole idea of castor correction bushes!
    the offset is nothing to do with the bush, it's all about the insert.
    If you have a 45mm hole, and a 30mm bush, you can offset the 30mm bush by 7.5mm within the 45mm outter diameter
  32. Dani_B19
    9,113
    346
    The defcon bushes are central, it wont alter the offest as they still retain the center of the hole theyll just tighten the handling up.
  33. superkarl
    9,406
    2,379
  34. Prawn
    11,418
    3,306
    Well that's gay! I was certain it was defcon who made the offset system!Who is it that does the offset castor correction bushes then?
  35. Sam_
    Sam_ Down under
    3,035
    480
    Super pro does eccentric ones, but they'd do castor rather than camber looking at where they sit?
    Find SuperPro Parts for My Vehicle
    Also, not sure if you saw on stacey's thread but I linked to h2sports mounts that you might be interested in. The only difference is you can't adjust camber and castor at the same time but probably less of an issue for you as you'd just want camber if it's track only I'd imagine. Tyre wear being less of an issue...
  36. Prawn
    11,418
    3,306
    Argh. stupid typo last night. Sorry guys.
    it's castor I want, all the way! LCR wishbones with the camber slots pulled right out has given me around 1.8 degrees camber, and a small increase in castor. I want to add eccentric rear bushes to increase the static castor a bit more, then add in GC top mounts to allow me to fine tune the camber and castor seperately.
    Sam: I've seen the H2Sport topmounts, but after reading up about them both on the thread on vortex, it seems that the GC ones offer more adjustment, and more range of adjustment too, so I'm going to go with those. Thanks though :)
  37. Prawn
    11,418
    3,306
    OK, so reading around I've clearly made a big cock up in understanding.....
    Defon inserts are for the FRONT Bushes of the FRONT arms arnt they?
    I thought for some reason that the defon inserts were for the rear bushes in the front arms, but reading on mod shack, I've totally cocked it up havn't I?
    It's OK, before anyone else does it:
    So, now that I've realised how stupid I am, the ultimate setup then, will be defon type inserts and 30mm poly bushes on the front of the arms, and something like the Super Pro eccentric rear bushes to increase castor.
    Sorted.
    That's a lot of money!" HAHA.
  38. Dani_B19
    9,113
    346
    Haha wondered what you were on about last night mate but i was pissed so thought it was me lol. Yes the defcon bushes are for the front of the wishbone.
  39. Prawn
    11,418
    3,306
    that's the problem, I was too :p
    Looking now, I need defon style inserts with mk1 30mm front bushes, then some eccentric rear bushes as well.
  40. Prawn
    11,418
    3,306
    Interestingly though, there seem to be two types of eccentric bush.
    These listd on the Super pro website:
    Part number SPF3397K
    And then these ones:
    Part number SPF2084K
    Which are the ones to go for I wonder?
