Prawn and BigAls A3 Track Car
Prawn Dec 29, 2010
  1. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Prawn takes wheel whores to another level......
  2. bigal 1
    bigal 1 Well-Known Member
    513
    252
    You've missed some 48s out. You have so many you don't know how many.
  3. Prawn
    11,583
    3,550
    It MUST be a race car now, it has a white nylon gear knob!
  4. Prawn
    11,583
    3,550
    Haha, just noticed the background on my parrot is Tori and I at a Rugby match about 4 years ago!
  5. Jason.s
    Jason.s Active Member
    2,879
    348
    You need an extension on that bad boy to bring it closer to the wheel :p
  6. Prawn
    11,583
    3,550
    Nah man, I've got a plan for that :) Extension will lengthen the throw as well, which is bad. Going to raise the shifter up, and cut the stick down.
  7. Westy
    Westy Well-Known Member
    17,443
    1,105
    It's already about 3 foot long! I remember from sitting in it at ace!
  8. Jason.s
    2,879
    348
    Short shift it is then. Its what i did last night, closer to the wheel and still shorter throw than standard was. You`re lucky you can raise the whole thing, Everything is sunken into the tunnel on the A4 :(
  9. Prawn
    11,583
    3,550
    as standard mine's mounted from under neath through the tunnel, I changed to a later shifter type, and moved it inside so the cables run through a hole in the bulkhead
  10. Jason.s
    2,879
    348
    Yeah i wouldnt have that option with gearbox being mounted other way and its run on linkages not cables.
    Also the added weight on the top of the lever has made it shift nicer and feel more precise. I now see why people go on about weighted knobs.
  11. moredoor
    moredoor Member
    160
    Mr Prawn here are some pics of what I was talking to you about at Ace, I'll be doing something like this to my mk4 track toy.
  12. Prawn
    11,583
    3,550
    That looks dead Smart Nando, really like that.
    Had an absolutely CRACKING day at Rockingham yesterday!
    Any prizes for guessing what happened?
  13. badger5
    9,543
    2,022
    the inevitable
  14. Sevv
    Sevv Pushing the limits..
    1,324
    120
    Good or BAd ?
  15. Prawn
    11,583
    3,550
    Boost hose blew out due to excessive heat, 1500 miles use on the road without issue, 2 hours on a trackday shows how much more stress it puts on things:
    Unfortunately, whilst working in the area fixing it up, we noticed this beasty on the manifold:
    Ohps. Looks like I'll be trying out a V2 manifold very shortly!
  16. Westy
    17,443
    1,105
    Wow! That's some split in the hose! Also I can't believe that mani crack. You are the first person to put one of these manis through it's paces so we don't know for sure that a V2 will last too much longer either! I know welly ran his for a while but we know that track days are a lot different to any hard road use.
  17. sportstractor
    sportstractor Chugger
    2,709
    Oh dear!
    This jizz should do the job
  18. badger5
    9,543
    2,022
    remember what we said about temps... and "anything" which is in sight of the hot bits will melt (my personal experience) they will melt/fail
    the colours of the collector and "odd" section of pipe look muchos hot..
    high egt's when used on track
    which is inevitable
    hope v2 works out more reliable
    you will be the official tester given your track use
  19. Prawn
    11,583
    3,550
    strange how the collector and that one little section are different colours isn't it? Was on actuator pressure most of the day too!
    Ah well, V2 manifold and WMI to come soon!
  20. stevegti2
    stevegti2 Member
    229
    13
    have just skimmed through this whole build alot of effort gone in a like it im building something similar at the moment my A3 is my daily so will only have a half cage but all the other trimmings :D
    might i ask what resistor ratings you used on all the airbags you removed i was gonna use a 501 bulb but thought i would see if someone knows first lol
    steve
  21. Prawn
    11,583
    3,550
    I didn't use resistors mate, I removed EVERYTHING totally including the control unit and most of the wiring.
    Light is removed on the cluster, as you can't code it out on my older car.
    On newer ME7.5 cars I believe you can actually code out airbags and / ABS if you so desire on the CANBUS.
    Be good to see some pics of yours at some point!
  22. moredoor
    moredoor Member
    160
    When I saw this I was thinking NOOOOO not the rods!!!! Happy it wasn't!
    As for why the manifold cracking where it did your pic tells the story really, the k04 turbo turbine housing is a bit on the small side so heat will start to build up in that area and for track use you may need to look at a cast or steam pipe manifold. WMI and maybe lower AFR's will help keep that hot spot under control.
  23. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It would actually help if they had welded the fkn thing properly, to me that looks as if they have fused that part in with no rod....as you can see it slightly con-caving...
    I think you are going to need something beefier like the frankenturbo manni perhaps?
  24. stevegti2
    stevegti2 Member
    229
    13
    ok cheers prawn lol ill get pics up of mine very soon ! promise :) and yes the manifold does look fused lack of rod is a ***** maybe its due to the rise in metal prices :no: lol
    is it a xs power ??
  25. badger5
    9,543
    2,022
    or something like this......... which would be more durable
  26. Prawn
    11,583
    3,550
    what's the manifold pictured Bill?
  27. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Looks a wee bit JBS?? :)
  28. aragorn
    18,491
    855
    filename suggests JBS
  29. Prawn
    11,583
    3,550
    ah yes, JBS-ko4 file name, makes sense :)
    Will contact XS today when Welly gets back to me, and see what can be done.
    I want to stick with the XS manifolds because I think they're great, just hope the V2 is better made.
  30. Westy
    17,443
    1,105
    Prawny, I know I text you but I thought I'd ask the question here too as it might be good info.
    I was wondering if you notice any driving difference between all your sets of wheels as the OZ Superturismos and the Team Dynamic wheels are a good 3kg per wheel lighter then a genuine audi 17" wheel like the S3 Avus?
    I'm looking at buying either a set of 17" 7J OZ Super Ts or 17" 7J set of Team Dynamic Pro Race 1.2 and these would give me a huge weight difference to my current 18" 8J S4 wheels.
  31. Prawn
    11,583
    3,550
    Don't get 7J westy, it's gay. they will look lost on your S3 arches, and 225 tyres will be properly over-tiring the rims. I ran 7J with my leon starfish wheels and they're just not wide enough really.
    both the wheels you mention are avail in 8j, my superT's are 8J, and TD PR1.2's are available in 8J if you go direct to Rimstock motorsport division, you can also get them in any offset you want, with the correct centre bore so no need for spigot rings. price last time I enquired was £100 per wheel + VAT, so great value as well!
    You do notice a difference for sure, it feels more lively and nimble on the lighter wheels, and the suspension seems to cope much better too, it's a better ride.
    Torque steer is also reduced, not that you'd suffer from it anyway.
    Just don't buy 7J! it's gay.
  32. Westy
    17,443
    1,105
    Only reason I was looking at 7J was because there was a set local to me going for £250 with tyres. I'm after a bargain if I can get it. Would 7J not look ok with spacers, also I would run 205 tyres and not 225.
  33. aragorn
    18,491
    855
    A4 TQS came from the factory with 225/45's on a 7J rim, they fit fine.
  34. Westy
    17,443
    1,105
    Road tyres would be fine I guess but most track tyres are slightly wider and squarer so might move about on the 7J rim too much.
  35. Prawn
    11,583
    3,550
    Why would you want to go down to a 205? No point in getting lighter wheels and decent tyres if you're going down on size so backwards on grip in that front. Stick with 225's at least! we want to try 235/40's next!
    They fit fine Kev yes, but they're on the upper limit of a 7J rim, with the tyre being almost 9'' wide and the rim only 7'', it's very much like a baloon, and they can roll about a bit. Coupled with the fact that track tyres tend to be 10-15mm wider than an equivalent size road tyre, and i think a 225 section trackday tyre will be **** on a 7J rim. my 225 yokos on 7.5J S3 rims are fairly baloon like already.
    they would fit for sure, but it's not ideal IMO
  36. aragorn
    18,491
    855
    The tread might be 9" wide, but the sealing bead is always inset.
    I agree that 7.5's would be better though.
    8's IMO need a 235, 225's always seem to look a bit stretched on an 8, and i properly hate that look. Sidewalls should be flat, not curving inwards!
    Fair point on the track tyres, i knew proper slicks were wider, didnt realise the semi-slicks were too.
  37. Jason.s
    2,879
    348
    225s on an 8 would be fine, they dont look stretched at all. 225s on a 9 barely have a stretch. Obviously its there and visable but its very minimal tbh. I was looking at 9s with a 225 tyre but expected a huge stretch so was plesantly surprised when i saw in person it was so small.
  38. aragorn
    18,491
    855
    Depends on your definition tbh.
    I like my tyre sidewall sitting nice and square, and the rim protector tucked down and protecting the rim.
    225 on an 8 ends up looking like this:
    http://gallery.myff.org/gallery/1271315/WP_000209.jpg
    With the rim protector bent back from the rim edge leaving that huge splayed gap, and the tyre sidewall sloping inwards.
    Does vary a bit from tyre to tyre ofcourse.
  39. badger5
    9,543
    2,022
    it is jbs one yes.
    being fitted to an LCR currently
    testing it once fitted.
    done before tests yesterday as datum
  40. Prawn
    11,583
    3,550
    Be very interesting to hear how you get on with it Bill. I've e-mailled XS to discuss getting a v2 manifold to put it through it's paces! waiting to hear back them.
    Few pics Dad sent over from Saturday:
    Our enormous pile of stuff!
    Andys comical new sunstrip:
    Quite happy with how it looks on the S3 rims too (225 track tyres on 7.5J rims)
