Prawn and BigAls A3 Track Car
Prawn Dec 29, 2010
  1. Prawn
    11,575
    3,546
    haha, sorry mate, It was out of my text window so I forgot I ment to reply :p
    I did see an S4 that had the letters of his number plate cut out, that looked amazing. From a distance it looked like a standard plate, but up close, the characters were infact holes! how much air flow you'd get through that I'm not sure though.
    For your car, I'd probably think a few decent sized holes under the plate, along with corresponding holes in the crash bar would be the best you can do, then remove the plate for trackdays.
    Like you say though, if you're getting enough air flow into the core anyway, is it needed?
  2. Andy P
    Andy P umop ap!sdn
    34
    Intercooler ducting / air dams. Its the most efficient way of getting air to pass through the core as it creates a higher pressure of air infront of intercooler.
    Something like...
    You want to seal off the intercooler to the front of the bumper so all the air gets directed through the core and doesn't take the easy route of going round it.
  3. Andy P
    Andy P umop ap!sdn
    34
    Also to note, the image of the Saab - the intercooler could extend up behind the bumper, but so long as its completely sealed on all 4 sides, air WILL flow though the very top of the core, utilising the whole frontal area. No holes required.
  4. Jason.s
    Jason.s Active Member
    2,879
    348
    What about drilling holes behind the plate and in the crash bar and using brackets to space the plate a little way out from the bumper so it wasnt covering the holes completely and the air could get behind the plate through the holes?
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    Trust me, even with my heat pump K04 running 22psi the inlet mani stays icy with just the lower grill to allow air in, I think all this hole drilling is a touch OTT.
  6. Jason.s
    2,879
    348
    For a road car with massive cooler yeah. Plus does an S3 bumper have sliightly bigger grilles/openings than a normal A3 bumper?
  7. Westy
    17,443
    1,105
    That could be a factor, different sized lower grill. But Even after an 8 lap session at Bedford last week the inlet was still cool when I came into the pits.
  8. Jason.s
    2,879
    348
    Is that awesome huge core cooler :D Plus you have one of the better gaskets from Bill dont you?
  9. <tuffty/>
    21,572
    4,045
    Bill and I have chatted about this before... might have a look at this in the new year... like the idea of it chaneling up the cooler behind the bumper too
  10. superkarl
    superkarl MAN OF STEEL
    9,553
    2,452
    my boss had a coarbon splitter on his race car, took it off because it was flexing at high speed and slowing him down, he then made one out of ply wood. think he's stuck with that since.
  11. Prawn
    11,575
    3,546
    Plywood is remarkably good for things like that, it's light, stiff, and most importantly, cheap and easily replaced!
    Will be mounted on a proper frame though, after a chat with Andy today, something that will generate actual downforce, should not be mounted to a plastic bumper
  12. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Marine sp* plywood seems to be the choice of many... A friend races in time attack and alot of them seem to use it with alloy bracing/ mounts
  13. superkarl
    9,553
    2,452
    yeh mounted as rigid as possible.
    will be interesting to know the differences you get from functional aero mods like a splitter and diffuser. its overlooked
    people just think 'il fit a big ass wing lad'
  14. Prawn
    11,575
    3,546
    Well, seemingly, well thought out, properly built home made aero can be VERY good if you follow all the principles correctly.
    THis is a golf that belongs to a northloop member, it has a 2.0 16v engine with around 180bhp, and weighs just over 1000kg.
    As you can see, it's got a front splitter, full alloy flat floor with drop down side skirts, and alloy rear diffuser, and it's ALL home made in his garage.
    he goes around the Ring in 08:20 btg!
    It seems to stick to the road like no other golf in history, and all the bikers out at the ring say that the turbulence comming off the back of the golf is similar to that of a radical rather than a small hatch back.
    Proof if ever it was needed that home made aero can definitely work
  15. Dani_B19
    9,336
    391
    Do you reckon that diffuser would fit under a s3? would look the nuts.
  16. Prawn
    11,575
    3,546
    im of the impression that anything can be made to fit just about anything if you want it to Dani, so yea, I reckon it could be made to fit!
  17. Dani_B19
    9,336
    391
    i like your thinking nick :). Think ill see how you get on first though as at over £100 i have other stuff to be buying first lol.
  18. superkarl
    9,553
    2,452
    yeh. you just need to have as little clearance at the front, and a large flat diffuser at the back sloping upward. low air pressure ftw
  19. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Does he trailer the golf? or is the aero removable as it looks like it would catch on speed bumps and not be easy to drive on uk roads
  20. Prawn
    11,575
    3,546
    the golf IS road legal, but I think it only ever goes on the road for it's MOT and things like that, it's only kept road legal for use at the Ring I believe.
    Nige's aero is pretty cool though, the side skirts you can see are actually rubber strip, the alloy part is only about 50mm deep, then the rest is made in 10mm thick rubber clamped to the alloy, which hangs down almost to the floor to create the ground effect, this wears out as it rubs along the floor, and every few trackdays he has to replace the rubber! Very clever idea I thought.
    He's also got little steel blocks under the corners of his splitter to act as skids after he kept grinding away the splitter.
    i don't think I'll go that far, but a home made splitter is definitely going to happen, coupled with a small diffuser I think
  21. Westy
    17,443
    1,105
    You wouldn't want to hit a puddle in that thing would you :sadlike:
  22. Jason.s
    2,879
    348
    Just read half of his thread. Thats some serious reading and some serious work gone into that car. I love the pit in his garage floor!! I want!
  23. jay1601
    jay1601 Well-Known Member
    1,344
    73
    really interested in the aero design for the A3. can't wait to see it put into plan :)
  24. mk1chopper
    1,092
    12
    does this mean the lcr splitter will be going?
  25. Prawn
    11,575
    3,546
    Noooooooooooo, the new splitter will sit flush with the bottom of the LCR splitter, which, lets me honest, is more of a 'lip' than a splitter.
    The A3 bumper slopes up loads as it comes forwards, so attaching a splitter at the lowest point would leave a wedge to trap air. Leaving the LCR splitter in place fills this wedge nicely.
    The splitter will be solid mounted to the chassis via the subframe and crash bar, and the bumper will be removable leaving the splitter in place :)
  26. superkarl
    9,553
    2,452
    does that Nige fella with the golf use an mx5 there too?
  27. Prawn
    11,575
    3,546
    Not that I know of Karl, Nige has been developing the golf for years now, hence why it's so extreme!
    Hullavington trackday booked for Andy and I, so the A3 / S40 show down we've been after will go ahead next Friday! can't wait.
    Also, in other news, I'm going to rig up some brake cooling ducts this weekend to ensure the brakes stay cool, I've not had any trouble with overheating yet, but it can't hurt to add some cooling in, especially if we're planning on doing some extended track sessions.
    It's even colour coded too!
  28. Westy
    17,443
    1,105
    Where will you put the ducting mate and how big do you think it will need to be to have any real effect on cooling?
  29. Prawn
    11,575
    3,546
    Well, I've been looking into brake cooling a bit, and it's not the sufrace that you need to cool, it's getting air to the centre of the bell so it can come out through the disc that really helps cool it down.Apparently the vanes in a vented disc are shaped so that they draw air from the inside of the disc and it passes through between the two plates, and out on the outter edge.
    I'll run these ducts, 60mm diameter, from the front bumper to the wishbones, then out along the lower wishbone and point them at the centre of the disc. I'll also remove the splash guards too.
  30. Prawn
    11,575
    3,546
    A few pics taken by Warren_cox at ADI, thanks for these mate!
    Will be getting the car ready for Hullavington this weekend, I'm making up a DIY camera mount for the cage, oil and filter change, and fitting some brake cooling ducts to help keep temps down.
  31. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Whens BBD coming to pick up these wheels foostick?
  32. Prawn
    11,575
    3,546
    When they're home dude, they're currently here, as seen on this handy webcam!:
    Those of you who know the location will likely be very jealous
  33. Westy
    17,443
    1,105
    Ah man, they at the petrol station round the corner from the ring :(
  34. Prawn
    11,575
    3,546
    Yup, in the Polo of Win! check out the 16'' Audi rims :rock:
  35. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    Pleasure mate; maybe get some better ones next year if I remember to take tripod!
  36. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Can't wait for the video of the trackday prawn.
    What's the octane level at that petrol station?
  37. superkarl
    9,553
    2,452
    its 102, its mental!
    edit; hang on, it might not be, i cant remember now
  38. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    That is the first car I have seen that those 16's actually suit..
  39. Westy
    17,443
    1,105
    The petrol station in the pic above isn't the one that sells the 103 rocket fuel. That's down in Adenau.
  40. Prawn
    11,575
    3,546
    Eds only does 97 Super I believe, although Aral in Adenau does 102, which is basically BP ultimate 102.
    Amazingly, the 102 in adenau is the same price as Eds 97! Well worth the drive
