Prawn and BigAls A3 Track Car
Prawn Dec 29, 2010
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    If I'm right can I cut one of the n75 wires on the plug that goes to the n75, wire I switch in with long cable and put the switch hidden in the front somewhere haha
  2. Scullies
    Scullies Well-Known Member
    1,543
    657
    You are 100% right :)
  3. Prawn
    11,373
    3,242
    N75 wired up today, boosts nicely.
    Seems to make 20psi at 3k without surge. Lean in the midrange though so pulled out. Oddly enough, still nice and safe rich top end, just lean in the midrange.
    More news tomorrow hopefully :)
    feeling good so far!
  4. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    How lean?
    Id imagine it could be flowing more mid range and similar at the top still. It's only a poor nB ecu so not really that good at adapting to a required fueling
  5. Prawn
    11,373
    3,242
    Held my foot in for a few seconds from 3-3.4k, 13.8-13.9. Too lean for me to continue with it, that's loading it up in 5th to test though.
    Pulling from 4k onwards in 3rd on boost it drops to 12's and 11's top end. feels fast.
  6. badger5
    9,378
    1,920
    thats not too lean to damage anything
  7. Prawn
    11,373
    3,242
    I'm no expert Bill, so anything near 14 scares me, I leave these things to experts like yourself! :)
  8. badger5
    9,378
    1,920
    well..
    wonder what it did on the dyno today,
    hmmmm
    interesting............ or was it..? :p
    <<tease>>
    16Klappe likes this.
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Don't think it's been near a dyno today has it Bill?
  10. Golfyste
    Golfyste Member
    66
    15
    Dyno?!?
    Good day?
    Nice and sticky tyres :eyebrows:
  11. Prawn
    11,373
    3,242
    Had a bit of a more relaxed weekend than ususal!
    Spent much of yesterday with Tori, but found time briefly in the afternoon to pop over to Thruxton to see a friend racing:
    And knocked up a quick heatshield to sit between the hot exhaust and the turbo intake:
    I also wired up the N75 quickly, and tested that it worked - confirmed. TFSI N75 works great.
    We had a little morning trip out today also.
    Some of you may recognise this place:
    And this friendly looking gentleman:
    Just a quick check to see that it's fuelling safe and I'm OK to continue driving it before it's mapped. This is still on the old hybrid map, and due to Bills excellent dyno software we were able to make overlays and compare new and old setups.
    So, the results.....
    Red line is the old ko4 hybrid, blue line is the new TFSI unit:
    Spool is a tiny bit later on the dyno, but on the road it makes 15psi before 3k, aside from that, on the same actuator pressure they're incredibly similar!
    Midrange torque is ever so slightly up on the new setup, whether that's because it's slighly leaner or not I don't know.
    Happy that it was running fairly well and things were as expected, we turned the N75 on!
    ^^^The old full boost map here was from before the last map on the new engine, so previous max power had been 307bhp at Bills. it's a great comparison of spool up though, again roughly 4-500rpm later.
    And the plots from todays results:
    348bhp and 283lbft, or in comparable terms elsewhere, 328lbft (given Bills calc of 16% lower reading on his)
    Considering it's made this from just 18psi at the top end, and it made peak power AT the rev limiter, I think we're doing pretty well here on the old map!
    EGT peak on the dyno on full boost was just 734 degrees, so promisingly low, and timing pull was absolutely zero across the board after a few tiny cf's on spool up.
    All in all, a bloody good result! Roll on mapping on September 5th!
    Massive thanks to Bill and Tuffty as always for fitting me into their incredibly busy schedule! you guys are awesome :racer:
    Jardo: please post your vids now :laugh:
    Vex182, Pedrosousa and <tuffty/> like this.
  12. 16Klappe
    5,795
    1,183
    And with no N75 -
  13. Golfyste
    Golfyste Member
    66
    15
    Looks Very promising dude!
    Looking forward to seeing it being mapped!
  14. 16Klappe
    5,795
    1,183
    Videos>words.
  15. Dani_B19
    9,058
    338
    Sorry for my poor memory but is this a standard tfsi turbo or has dan worked some magic on it?
  16. Prawn
    11,373
    3,242
    Basically standard Dani. A 1 bar actuator and a TINY bit of port matching at the flange, but that's it :)
  17. Pedrosousa
    Pedrosousa Member
    174
    Good news are coming Prawn!!!! Excelent
  18. bigal 1
    bigal 1 Active Member
    480
    212
    43
    I have never seen a shot like that before. Great, just shows what a Proper tyre does under proper use. Most impressed
    Pedrosousa likes this.
  19. Gops
    3,194
    664
    Excellent results so far! I got 278 lb/ft at bills which is quite alot looking at your calculations! But looks great prawny, you've done such a great job so far!
  20. Prawn
    11,373
    3,242
    There is a bit of carpet glue involved there too BBD, to stop it wheel spinning on boost, but it was VERY obvious how sticky these are on the rollers, you could really hear it sticking to the rollers which you don't tend to hear at all with road tyres.
    This also lead to us picking up a LOT of stones when leaving B5, which took most of the journey to falls out of the various places they'd been lodged!
    Just uploaded the graphs again in a better size so you can actually read them:
    Actuator comparison:
    Boost comparison (Pre final map on the hybrid)
    And the plots just from yesterday:
    Thanks again to Bill and Paul for doing this for me :) it's highlighted that at the very top end, I'm either running out of injector or fuel pump (starts to get leaner above 6k on full boost)
    NIki reckons he's taken the 440 greens beyond this many times before, and I'm on a stock LCR pump, so I'm almost certain it's the pump. I've got a walbro 255 pump to drop in this week, and will be taking a 4 bar FPR up to R-tech with me so we can add another 15% fuel if required.
  21. badger5
    9,378
    1,920
    + sprayed on contact adhesive ;)
  22. wild willy
    wild willy Member
    67
    That looks awesome, no cf's and still climbing at 7000 rpm:yes:, dare we speculate at a possible 400 bhp.
  23. Prawn
    11,373
    3,242
    I'm not sure about 400, but it's certainly very promising!"
    Top end fuelling was pretty rich, but as it starts to lean out (fuel pump related I think) above 6k you can see the power start to rise further.
    It peaks at 7392rpm, just 8rpm before the hard cut limiter, so we can safely say that's the soft cut stopping it going any further and it's peaking AT the limiter. Boost at that point is just under 18psi and fuelling is still at a safe 11.5:1, so mapped to hold 20-21 or more at a similar fuelling level, with maybe a few degrees more ignition, then who knows!
    This is what our friendly Badgerman said on bookface:
    A good and totally independant view point that certainly suggests big potential :)
  24. beachbuggy
    1,931
    201
    I'm a little surprised I have to say, especially how easily it's making the power. I thought we'd get near the old hybrid power but honestly thought as it stood yesterday it would make nearer 320-330 on the old map with a bit more once mapped properly, but it seems like its leaps and bounds above my expectations, and to be near the 2ltr tfsi engine power once tuned is great news..
    I've said for a little while the tfsi was pretty badly runner to head match ported and I did put quite a bit of effort opening out the runners on this setup so maybe saying a pure stock tfsi k04 will do this maybe or maybe not un realistic along with nicks engine and wmi.. However, everything turbo setup wise is easily repeatable , the more can get out of the stock version the more I hope the hybrid will take..
  25. boomsly
    boomsly New Member
    9
    seeing a few pages back that a 4wd setup is possible DP dependant, this looks very interesting indeed as its making me wonder if i should carry on with my k04 hybrid or swap over to the TFSI setup you guys have shown here.
    any ideas on cost for the setup once testing has been done? pm's would probably be best
    thanks
  26. badger5
    9,378
    1,920
    To me this remains the $64,000 question
    Dan will be able to confirm his costings/prices in due course.
    Performance wise is certainly has merit
    Ecconomics TBC
  27. bigal 1
    480
    212
    43
    That makes sense Bill, I thought something was there. If the tyre melted like that wed would only get a couple of laps in.:detective2:
  28. beachbuggy
    1,931
    201
    Dont worry bill, sure someone will copy my design and sell it on eBay!
  29. badger5
    9,378
    1,920
  30. superkarl
    superkarl MAN OF STEEL
    9,374
    2,370
    how does that compare to yours dan? both cost and design wise?
    I understand the frustration but people see a market and go for it, like creation motorsport with 3inch tips.
    A possible new source for your kit perhaps?
  31. <tuffty/>
    20,847
    3,687
  32. superkarl
    9,374
    2,370
    think the variety of pics are misleading, but it says only the first pic is what you get, no nylocks there, thank god.
    Im trying to restrain myself from saying bye bye gtx and hello tfsi hybrid, need to stay clear of all this really!
  33. Prawn
    11,373
    3,242
  34. beachbuggy
    1,931
    201
    I was aware, I was being a bit ironic in my statement;-) its nearly a blatant copy of mine except p1ss all thought gone into this one, counter sunk bolts , non angle studs for Tfsi fitment, which are crucial. I have an idea of who it is.. Funny how it was released the day after testing !
    No Matter though as with mine at least you'll know its been tested fully, actually fits and been r&d! Plus your get a complete kit and not just a lump of metal.
  35. Prawn
    11,373
    3,242
    Mystery seller even read your comments and amended the auction 15 minutes ago!
    <tuffty/> likes this.
  36. badger5
    9,378
    1,920
    Its a piss take if its someone off here....
    Someone has crossed a line if so
    Dissapointing if it is.... who its "thought to be"
  37. Scullies
    1,543
    657
    hahaha, that's classic.
  38. badger5
    9,378
    1,920
    BBT for the win
    Shame some folks feel the need to knock off stuff they see others put effort in to.
    Shame on them... especially if on here.. Kinda sours things somewhat..
    Scullies likes this.
  39. <tuffty/>
    20,847
    3,687
    Meh... still misleading as the bit 'update your KO4 manifold' infers you can use your existing K04... tbh a more correct description would be TFSI turbo to 1.8t adaptor... seeing as the hotside is integral to the TFSI manifold and therefore the whole K04 turbo... just misleading...
  40. Scullies
    1,543
    657
    lets see how long it takes to change this time
