PR CODES (da vinci code your Optional Equipment!)
pea. Jan 3, 2007
  1. pea.
    pea. Member
    101
    Ever wandered what your car actually came with when it was made?!
    I'm hoping this should help-
    When your car was built it was issued a sticker like this-
    You should find it in your Service Schedule book, inside page
    All the codes listed to the right of the Optional equipment represent an Optional extra or emission
    Apologies to those who know about this already but I personally would have found this useful a month ago...
  2. pea.
    pea. Member
    101
    A9D “Ambition” equipment
    B0A Component parts set without country-specific design requirement
    B99 Type approval EC
    C09 Operating permit, alteration 9
    C3F Cast alloy wheels 6 1/2J x 16 5-arm style, offset 42
    CC3 Alloy wheels 7J x 17 nine-spoke style, offset 38
    D2F 4-cylinder gasoline engine 1.8 L/132 kW 20V turbo, base engine is T8C
    E0A No special edition
    F0A No special purpose vehicle, standard equipment
    FA0 Control of standard production
    G0N Five-speed manual transmission for four-wheel drive vehicle (three-shaft transmission)
    G95 Front shock absorption
    HA4 Tires 205/55 R16
    J1L Battery 280 A (60 Ah)
    J24 Suspension range 24
    K8G Hatchback
    L0R Right-hand drive vehicle
    L43 Suspension range 43
    MV0 4-cyl. Gasoline engine 1.8L/132 kW 20V turbo, EU 3D base engine is T8C
    N4X Vachette leather seat covering
    Q1D Sports front seats
    QG0 Without service interval prolongation
    QG1 Service interval prolongation
    QZ4 Power steering (limited steering lift mechanism)
    T8C 4-cylinder gasoline engine 1.8L unit 06A.C
    U1B Instrument insert with mph speedometer, clock, tachometer and trip odometer
    U1M Instrument insert with mph speedometer, clock, tachometer and special color trim
    V89 Suspension range 289
    X2B National sales program Great Britain
    0A1 Two doors
    0AL Front stabilizer
    0BJ Rear stabilizer
    0CJ Vehicle class differentiation 8L0
    0F2 Fuel system for carburettor gasoline engine
    0FA Standard manufacturer sequence
    0G4 Cable gearshift
    0GE Emissions concept EU 3
    0L2 Electric throttle actuation
    0LL Special plates/stickers/safety certificates for England
    0N5 Standard rear axle
    0RA Without ignition/starter switch locking system
    0SS Labels/plates in English and French
    0TD Front and rear floor mats
    0VF Information kit in English
    0W2 Label for central electric English-speaking countries
    0YL Weight category rear axle weight range 23
    0YZ Without determination of weight category for rear axle
    1AH Electronic differential lock (EDL)
    1AT Electronic stabilization program (ESP)
    1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    1D0 Without trailer hitch
    1E1 Activated carbon canister
    1EX Special identification plate for EC
    1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
    1GL Front shock absorption, sports design 2
    1GX Front shock absorption, sports design 3
    1H0 Without proportioning valve
    1JV Rear shock absorption, sports design four wheel drive
    1KE Disc brakes, rear
    1LE Disc brakes, front
    1LN Disc brakes, front
    1N1 Power steering
    1N6 Power steering
    1PC Wheel bolts with anti-theft protection (unlockable)
    1S7 Tool kit and aluminium Jack
    1SA Without additional engine guard
    1T2 Warning triangle
    1WC Transmission shaft w/108mm in diameter
    1X1 Four wheel drive
    1YC Transmission shafts for rear axle diameter 100
    1Z5 Increase in initial standard fuel filling
    2A4 Delivery equipment for shipment (transit coating) with thick seat cover
    2B1 Additional exterior noise suppression
    2C5 Axial and vertical adjustable steering column
    2D1 Complete CD enhancing under body panel
    2G9 Filler neck module 2 with insert
    2JB Standard bumpers
    2LB Fuel tank with special material treatment
    2PV Leather trimmed sports steering wheel
    2V1 Dust and pollen filter
    2W0 Fuel filler cap
    2WA Without additional tires
    2Z1 Type sign at rear and “Quattro” nameplates respectively
    3B0 Without additional child seat anchor
    3C1 Static lap belt, centre rear
    3FA Without roof insert (standard roof)
    3FE Electric slide/tilt sunroof with sun screen/sunblind
    3H7 Backrest release with easy entry for front seats and add, backrest release for the inner side of left front seat
    3L3 Manual height adjustment for front seats
    3NC Rear seat bench/backrest, split folding
    3Q1 Rear headrests
    4A3 Seat heater for front seats separately controlled
    4E0 Tailgate/trunk lid unlocking from outside
    4GP Windshield, heat-insulating glass with sun band and viewing window for vehicle identification number
    4K1 Radio remote controlled central locking
    4K4 Radio remote controlled central locking operated from inside and separate trunk release
    4L2 Dipping breakaway inside rear view mirror
    4M0 Without cup holder
    4P0 Rear floor panel module, type 1
    4R1 Power windows
    4SD Left vanity mirror illuminated
    4TD Right vanity mirror illuminated
    4UE Airbag f. driver a. front seat passenger
    4UF Drivers and front passenger airbag with front passenger airbag deactivation
    4W0 Without cassette and CD storage unit
    4X1 Side airbag front
    5C0 Without special body measures
    5D1 Carrier frequency 433.92 MHz-434.42 MHz
    5E1 Without sill top with door cover
    5J0 Without rear spoiler
    5K1 Paint preservative (wax)
    5RV Outer right rear view mirror: aspherical
    5SJ Outer left rear view mirror: convex
    5TC Without decorative inserts
    6A0 Without fire extinguisher
    6E0 Without centre armrest front
    6M0 Without tie down straps/net/pocket
    6N0 Without mud flaps
    6PA Plastic hand brake lever handle
    6Q2 Leather gearshift knob/handle
    6R2 Leather gearshift boot
    6TS Outer right rear view mirror: non-spherical, large viewing field
    6U0 Without additional seals outside
    6V1 Rear trim panel (ECE)
    6W5 Front license plate bracket
    6XD Outer rear view mirrors: powered, heated
    7A0 Without CD changer/CD player
    7A2 CD changer
    7AH Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
    7CC Label for radio remote control for
    7E0 W/o heat accumulator/auxiliary heating
    7L0 Without inertia benefit system/deceleration fuel cut-off/idle stop valve
    7M0 Plastic scuff plates in door apertures
    7P1 Power adjustable lumbar support in front seats
    7Q0 Without navigation device
    7QA Without CD/DVD for navigation
    7X0 Without park distance control
    7X1 Ultrasonic park distance control
    8BK Twin headlamp for driving on the left with integrated high-beam headlight
    8CC Speedometer sensor without seal (electronic speedometer sensor)
    8F2 Side turn signal lights
    8GL Alternator 120A
    8JK Ellipsoidal headlight for driving on the left
    8K0 Without special low beam mode
    8M1 Rear window wiper and washer system with intermittent control
    8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    8Q1 Headlight-range adjustment
    8RY Speakers with BOSE sound
    8S5 Two reading lights front
    8T0 Without cruise control system (CCS)
    8TD Rear fog light for driving on the left
    8UD Radio “concert”
    8W1 Washer fluid level indicator
    8WA Without front fog light
    8X1 Headlight washer system
    8Y1 Two-tone horn
    8Z5 Not hot country
    9AK “Climatronic” with impact pressure control free of cfc
    9D0 Without preparation for two-way radio installation
    9M0 Without auxiliary/parking heater
    9P0 Without seat belt warning light
    9Q2 Multi-function indicator/on-board computer with check control
    9T1 Heated washer nozzles, front
    9U0 Without brake pad wear indicator
    9W0 W/o car phone preparation/installation
    9X7 Heated door lock cylinder right with micro switch
    9Y1 Outside temperature display
  3. pea.
    pea. Member
    101
    Please please please, if you see any mistakes let me know as you'll be helping me-
    The only code I have that I couldn't find was X2B, any ideas anyone?
    Gonna go put my hands in some iced water now!!!
  4. murph
    murph Member
    95
  5. ak_quattro454
    ak_quattro454 Member
    108
    great work, very useful to have em all listed in one place.
    is that the complete list of extras on the a3 8L???
  6. pea.
    pea. Member
    101
    murph-
    No mate, although that looks annoyingly useful!
    I went down to the local dealership and he printed loads of pages off for me, very helpful!
    I did think about just scanning them in but without wanting to sound like a tart... I need to get my typing speed up!
    ak-
    I was hoping one of the 'clued up' members could help there, I couldn't honestly say, this is just what was printed off for me
    The first page also showed my precise engine spec etc. so it may be just relevant to a 1.8T Sport Quattro
    Sure someone will be along to give advice soon-
  7. Darthvader
    Darthvader "The Darkside"
    153
    Some great work there buddy.. i'm defo having a read of my book in the morning....
  8. buckas
    buckas Member
    749
    yeh same here, cheers gunshow - nice work :thumbsup::thumbsup:
  9. buckas
    buckas Member
    749
    nice one thanks - found a most of my codes on the description, these one's below i have on my sticker but weren't listed on the meanings (in their respective rows if that means anything?):
    7A0 - 4UF - 6TS
    1LE - 1AT
    3FA - G95 - 5TC - 7X1
    0YL - L43
    8JK - U1M - QZ4
    D2F
    CC3
    4K4
    0GE - QG1
    anyone know what they mean also ? cheers
    also mine says at the top
    A3.........quatt.1.8.........R4
    132KW.............M6S..........11/02
    what's the R4 mean? lol
    drew
    p.s sticky this topic imo ;)
  10. Tequie
    Tequie New Member
    13
    yup, sticky, i agree, nice work
  11. Tequie
    Tequie New Member
    13
    buckas, here's your codes intepreted using that website mentioned in this thread
    7A0 = without CD changer/CD player
    4UF = drivers and front passenger airbag with front passenger airbag deactivation
    6TS = outer right rear view mirror: non-spherical, large viewing field
    1LE = disc brakes, front
    1AT = electronic stabilization program (ESP)
    3FA = without roof insert (standard roof)
    G95 = front shock absorption
    5TC = without decorative inserts
    7X1 = ultrasonic park distance control
    0YL = weight category rear axle weight range 23
    L43 = suspension range 43
    8JK = ellipsoidal headlight for driving on the left
    U1M = instrument insert with mph speedometer, clock, tachometer and special color trim
    QZ4 = power steering (limited steering lift mechanism)
    D2F = 4-cylinder gasoline engine 1.8 L/132 kW 20V turbo, base engine is T8C
    CC3 = alloy wheels 7J x 17 nine-spoke style, offset 38
    4K4 = radio remote controlled central locking operated from inside and separate trunk release
    0GE = emissions concept EU 3
    QG1 = service interval prolongation
    Gunshow, maybe edit the original post and include these?
  12. buckas
    buckas Member
    749
    LOL! whoops, didn't see that web link - cheers Tequie :beerchug:
    drew
  13. Pete69zx
    Pete69zx Guest
    Excellent work!
    Many thanks.
  14. pea.
    pea. Member
    101
    Ok, cheers guys, i've updated my original post to include the new ones
    Keep 'em comin!
  15. ak_quattro454
    108
    these were also listed on mine
    1GX - Front shock absorption, sports design 3
    1N6 - Power steering
    V89 - Suspension range 289
    decoded them using that link
  16. pea.
    pea. Member
    101
    I've updated the list with yours now ak
    I've noticed some of these are doubling up?
    1N1 and 1N6 - both power steering? dunno? i'll keep updating anyway!
