poxy squeak what the..
speedy lynn Oct 26, 2011
  1. speedy lynn
    speedy lynn Member
    51
    help! has anyone had a loud squeak on there S3 I think its on the front it is loud and only stops if I go on a smooth straight road if I park or go into the garage its off squeak squeak its doing my head in some said it may be the suspension front legs what ever that is ,Ihave pushed the car down on each corner, it squeaks on all corners, any ideas would be welcome, and before you all tell me to turn up the radio, done it and I can still hear the f...ing thing, it does my head in
  2. superkarl
    superkarl MAN OF STEEL
    9,374
    2,370
    jack it, silicone lube all the antiroll bar bushes, other bushes, drop links, shock mounts
    could be shocks n springs.
    could be top mounts.
    theres just so many things it could be.
    MattW86 likes this.
  3. MattW86
    MattW86 Member
    84
    I have a similar squeak which comes and goes, i believe it is to do with the anti roll bars. There is supposedly a plastic 'shim' which after a while wears down and you get the squeak. look at getting some new anti roll bars or put some grease on them.
    I could be wrong, one of the more knowledgeable guys will give you a definite answer
    Good luck
    Matt
  4. superkarl
    9,374
    2,370
    no shims on the anti roll bars.
    the amount of stress they are under when loaded its common for them to squeak (i've got to lube my girlfriends up this weekend, waheeyyyy)
    its not difficult to under the ARB mounts and squirt a little copper grease in there.
    if you have squeaks id just go mad with some spray silicone lube under the car lol
  5. antwan
    antwan Member
    85
    Loose wheel bolts, Bottom ball joint/s dry ? but you would normally hear them squeaking or creaking when you turn the steering wheel. or you could try spraying each bush or joint with some lube to see if the noise lessens or goes away.
  6. speedy lynn
    speedy lynn Member
    51
    yes thats the right description it creaking, I will spray everything, is there a special spray as I dont want to replace every bush on the motor because all the rubbers have rotted with me using the wrong grease, cheers Antwan
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    The only thing that got rid of my creaks was changing the top mounts...with a load of white grease for good measure...
  8. speedy lynn
    speedy lynn Member
    51
    Thanks Dave, any idea of the cost of the tops mount, and how difficult to do? would be gratefull, PS the rear light I got from you last year fitted just as you said nice and easy, hope this top mounts replacement is as easy CHEERS LYNN
  9. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    Halfords will sort you,spray every joint in view :) there is a link to doing ARBs somewhere,I'll find it.
  10. s3dave
    10,110
    736
    Great,, top mounts SKF SEAT | Euro Car Parts UK’s No.1 Car Parts Retailer
    They will have 20 - 30 % off sometime in the month then,,, buy buy buy
    dificulty --- if on standard suspension, a bit of a stripdown, there will be guides on here, if on coilovers its very easy...
  11. A3 T
    A3 T Lord Of The Rings
    1,062
    14
  12. speedy lynn
    speedy lynn Member
    51
    thanks to all the boys, i'll let you know sunday night how it goes or perhaps the poxy noise will still be there?????
  13. speedy lynn
    speedy lynn Member
    51
    thanks mate will try the easy option first if I still have the noise, I will then go and get the top mounts, cheers Dave
