Powervalve (BCS) 90mm Downpipe
BCS Nige
For everyone chasing big power, images of the 90mm DPand Flex next to our 76mm variant.
Nige
 DSC1258
 DSC1259
 DSC1262
Reactions: Smirky
@S3Alex got you written all over it lol
It has but need to talk about V-banded connections and low end response.
Nige has been very helpful and I'm still thinking about what's best.
Reactions: Sandra
Nige what's the expansion chamber is it ? On the 76mm but not there on the 90?
200 cell cat, if you zoom in you can just about see the writing.
Bet the 90mm is a tight squeeze as the 76mm is tight and hard enough to fit
I'm still thinking about this.....
Nige was very helpful in the other thread re the effects of a large bore system on low/mid range response.
What I'd need would be a V-banded downpipe,with either an integral dump tube,or a separate one,and then I would guess,a 90mm system from there back.
The next question is would that all fit into the space around the turbo,and prop shaft etc.
Reactions: Smirky
It does look a bit tight in there
That's the thing...it all does get very tight.
The extra size of the turbo,plus the external wastegate leaves very little room.
I think I need Nige's advice...
Reactions: Smirky
It's all very tight but with careful application 90mm is possible
Reactions: S3Alex
I'm sure you guys can but how would you run this lot....
A separate dump tube or integrated.
Then as before would it be a 90mm system back from there?
I think the separate dump tube would be feasable but without checking it's hard to say...
Reactions: S3Alex
Hmmmm
I can see you'd need the beast for a consultation.
