Powertrack insert, about to go in!!
J Eyo Mar 7, 2014
  1. J Eyo
    J Eyo Polo GTI (6) R
    220
    17
    Just received the power track insert to give me permanent 50/50 awd on my s3 bam; going in next week sometime, cir clip version. Its sitting on my shelf at the moment, great piece of machining, 17mm version id imagine you could just buy yourself at 17mm bolt?? but the cir clip version very specific shape and design. Will let everyone know how it feels and what changes I've noticed! (And eventually over time if it blows out my haldex) Pretty excited since it was only $100 compared to over $1000 for the illusive haldex upgrade
  2. sportquattro
    sportquattro Active Member
    835
    51
    Very keen to hear how you get on with this, just read their eBay advert and it sounds good alternative to the controller upgrade hopefully it works well with no ill effects long term
    Nige
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Is this the same as Andrew is producing?
  4. J Eyo
    220
    17
    Powertrack is in, so first impressions: car doesn't lurch at all on take off, stays utterly flat on stock shocks, it just jumps forwards. No binding or grinding or any steering, skipping or noise issues at all at any speed....yet. The only big difference so far is take off feels much more instant and flat. One notable but lesser change, braking feels different, especially from high speed, a little less controlled like the back wants to wiggle a bit, and on a lesser note the car feels as if it wants to free roll a lot more through neutral at speed (also very noticeable when rolling to a stop, feels as if it'll just keep going almost like an auto). As the placebo effects wear off I'll be able to feel things a little better. I'll keep everyone posted as/if anything develops
  5. Andrew@A.L.D
    3,877
    617
    I do sell them too but for less than $100
    They guy that sell the Powertrack ones is a complete c**k as i'm looking into adjustable ones and he don't like that at all..
  6. daz-20vt
    daz-20vt Well-Known Member
    2,835
    582
    Is yours out already Andrew?
  7. Andrew@A.L.D
    3,877
    617
    Not the adjustable ones no not yet
    The problem is space
    I do make and sell the inserts
  8. daz-20vt
    2,835
    582
    Still in progress then.cool ill wait for 6ours i reckon, im sure your keep us posted. Daz
  9. Simon_S3
    Simon_S3 Member
    94
    Hi Andrew how much are your inserts as i'm interested in one?
  10. Andrew@A.L.D
    3,877
    617
  11. Dani_B19
    9,258
    379
    Has yours been tested andrew? Whats the verdict on how it transforms the car?
  12. Andrew@A.L.D
    3,877
    617
    The inserts like the powertrack yes, have had the same reports back as the powertrack insert as it a copy
    As for the adjustable ones space is the problem so looking into a electronic was of adjusting
    I do have the fancy haldex controller you see where its fully adjustable and to copy that it would be very hard with all the electronics in the ecu and knowing what they all are..
  13. daz-20vt
    2,835
    582
    So are tuere any disadvantages to your insert? Im not sure why your making an adjustable one?
  14. Andrew@A.L.D
    3,877
    617
  15. Simon_S3
    Simon_S3 Member
    94
    Am i right in thinking the inserts do the same job as haldex controller by making the drive 50/50 but its just not adjustable?
  16. Andrew@A.L.D
    3,877
    617
    That's right. 50/50 all the time.
  17. westcoast a3
    westcoast a3 Active Member
    318
    37
    Is fifty fifty all the time better ??
  18. J Eyo
    220
    17
    Andrew have you thought about making that middle pin (the part that is elongated to create the 50/50) threaded and lockable? that way you could reach under the car and spin just the centre bore the raise or lower the pin effecting the power distribution, perhaps have markings around the top of the pin showing the split, and have it notched so you can line up some sort of guide when you turn it. Im never going to need to change it from 50/50. Just a quick q, cause a few of you boys here seem to be the leading authority, just bought myself a replacement clutch switch, was from italy, was too long, and it had a square back instead of a round back (is a blue colour) i cut the lever part to the same length as my last clutch switch, but the clutch now seems super grabby and when i press it down in 1st and 2nd it really throws the clutch open and the car jerks unless I'm really careful, wrong clutch switch sending a strange message? or just, made the actual spring loaded part too short by trimming it? ideas? i know this should be in a different thread but thought maybe someone would know
  19. Simon_S3
    Simon_S3 Member
    94
    Hi Andrew, can you pm me your PayPal details and I will send payment across 2nite for you for the insert. Cheers
  20. Andrew@A.L.D
    3,877
    617
    I need to know what type of insert you have in your car now
    There is two types. one is a 17mm hex bolt and the other type is held in place with a cir clip
  21. Andrew@A.L.D
    3,877
    617
    Maty J
    yes i have looked into that but the Haldex oil runs around the Haldex system under 5 bar pressure
  22. <tuffty/>
    21,161
    3,837
    The clutch switch has no influence over the operation of the clutch... its just a switch.. its used by the ECU so it can adjust how the engine runs to prevent jerking etc...
    There is no need to cut a clutch switch plunger to length as its self adjusting
    s3gazz likes this.
  23. Chlippo
    Chlippo Member
    679
    15
    I am getting the powertrack one too.
    I guess they are the same and function the same way as Andrew ones till now, but I can test and compare if Andrew have any interest in it.
  24. Andrew@A.L.D
    3,877
    617
  25. Simon_S3
    Simon_S3 Member
    94
    Hi Andrew, i have had a look and mine is the circlip type. I use my car some weekends on the road but mainly for track days every couple of months, what are the disadvantages of fitting this insert if i do use it on the road. eg. do things wear out quicker, driveability etc. Cheers Simon
  26. daz-20vt
    2,835
    582
    I would also like this info please Andrew. Also how hard is it to check which i need? Do i need it on a ramp or can i look underneath the car on the floor?
    thanks
  27. Chlippo
    Chlippo Member
    679
    15
  28. Simon_S3
    Simon_S3 Member
    94
    I did mine on the floor daz just jacked on the rear diff cradle and put on axle stands. I found a picture and just felt up the top and could tell which one it was, you can use a mirror also.
  29. daz-20vt
    2,835
    582
    Cheers guys!! Looking forward to this!!
  30. Swervedriver
    Swervedriver Member
    91
    Any feedback from people using these on the road?
  31. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    So this insert basically locks the Heldex, converting the car to permanent 50/50 4WD? How does it work?
  32. Andrew@A.L.D
    3,877
    617
    it restricts oil flow in the Haldex system putting more pressure on the clutch plates in the rear diff
    Not practical for every day driving
  33. daz-20vt
    2,835
    582
    I keep meaning to buy one of these. Andrew my car is mostly a track car and the occasional drive on the road. Is this better or worse for reliability/use?
  34. Swervedriver
    Swervedriver Member
    91
    Is it possible to do a 60/40, or 70/30 version?
  35. Andrew@A.L.D
    3,877
    617
    If its running 50/50 all the time then the clutch is fully engaged so the pump is running all the time to keep the clutch engaged so thats the only thing you will have reliability problems with
    Don't expect your Haldex clutch plates to last long
  36. Andrew@A.L.D
    3,877
    617
  37. jasongtr
    jasongtr Active Member VCDS Map User
    441
    37
    fair play posting that to say they are cheaper, not many would
  38. snowy
    snowy Active Member
    425
    106
    43
    Anyone with a lathe will be at it
    You could halve that price and still make a tidy profit - more sales vs higher unit price - you could even make $ overall ;)
    A version less than than 50/50 wouldn't burn you clutch plates out any quicker, imho
    For anyone interested in knowing what these inserts affect:
  39. Andrew@A.L.D
    3,877
    617
    Time Consuming for me when I have head work to do
  40. Miguel_S#
    Miguel_S# Active Member
    335
    29
    with Powertrack, its possible to turn off haldex?
