powersteering fluid s4
TURBOTRONICS Jan 19, 2012
  1. TURBOTRONICS
    TURBOTRONICS Member
    187
    is it possible to change the fluid on my powersteering and if so is it a big job to do
    thebsteering has developed a noise when turning at a certain point and i wanted to change the fluid see if it would help
  2. quattrojames
    14,060
    583
    Turkster (I think) changed it on his 2.5 to good effect, so it can be done. Hopefully he'll chirp in with how he did it.
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,249
    192
    TURBOTRONICS likes this.
  4. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    TBH all i did was unscrew the cap, turn the steering to full lock for 60 seconds, let any fluids get pumped right down into there channels and top up the bottle, then did a full lock the other side and did the same, once the squeel was gone i topped up the bottle to the line and put the cap back on, job done,
  5. TURBOTRONICS
    TURBOTRONICS Member
    187
    thanks for this link i will have a look when i get home it looks promising and not to complicated
  6. TURBOTRONICS
    TURBOTRONICS Member
    187
    thanks for the post i will give this a go before i flush the system see if that helps
  7. quattrojames
    14,060
    583
    Ok my mistake, Turkster obviously did a bleed rather than a fluid swap.
