  1. jim s3
    jim s3 Member
    321
    what power do remapped s3's push out at the wheels
  2. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Depends entirely on the remap, the weather on the day, and the rolling road. Anything from 240-260 in the real world, many will claim more.
  3. jim s3
    jim s3 Member
    321
    my print out shows 209 power tyre, and dispersed power 24.5
  4. dultanur
    dultanur all promises, no action :)
    407
    i would think even less? standrad 210 s3 s usually see around 160 at the wheels dont they? so should be around 220?
  5. jim s3
    jim s3 Member
    321
    so is mine about right or still down on power
  6. ChriS3
    2,239
    27
    You'll lose 60-80bhp through the transmission depending on how it was RR'd, and flywheel BHP is a calculated figure. BHP at the wheels is what to go by, and if you're getting 209 then you're in the right ball park.
  7. jim s3
    jim s3 Member
    321
    i only lost 24.5 through mine
  8. ChriS3
    2,239
    27
    Now that's not exactly realistic....
  9. dultanur
    407
    24.5 is a veeeeery low loss. i think there was a miscalculation, as chris said shpuld be at least 60hp.
    did they rr your car while tricking the haldex off? (applying the handbrake or removing the ABS fuse?) if so it would only show FWD losses.
  10. jim s3
    jim s3 Member
    321
    im not sure it was done correctly now he even pointed out that it lost 24.5 through the transmission..
  11. dultanur
    407
    find a good tuner place bud! solve all your problems at once.
  12. jim s3
    jim s3 Member
    321
    no we had all 4 wheels spinning
  13. ChriS3
    2,239
    27
    Pulling the ABS fuse will still allow the haldex to function and the rears to turn, and putting the handbrake on will show massive transmission loses. Sounds like they might have dropped the propshaft or done something very odd.
  14. 242spot
    242spot Member
    101
    Had mine on the dyno today for a fueling problem im having.
    Mine made 226 at the wheels ... a little sick needs a new fuel pump. will post the fiqure when it gets re-tested fixed on wed
    Ps mine is Revo'ed on 8 boost 7 timing 226 the guy said was about 260-265 at the fly.
  15. jim s3
    jim s3 Member
    321
    they didnt pull any fuses or any thing they just pulled the car on the rollers strapped it down and then calibrated the system then done the power run.
