Power to Sub under Seat A3
BrianL2 May 13, 2013
  1. BrianL2
    BrianL2 New Member
    Hi
    Just got my first Audi. 2010 A3
    Am changing the head unit and have bought all the leads etc.
    I have a Pioneer TS WX11A small sub which I want to put under the drivers seat
    Can anyone advise where to pick up the power please. It needs 10a supply (plus switched signal which I thought I would get off the feed to the head unit)
    Brian
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Ideally you should run power direct from the battery although as it is a relatively low current feed you should be OK picking it up from the 75x relay board under the steering column, or use one of the redundant fuses in the fusebox
