power steering pump
chimp1967 Feb 8, 2011
  1. chimp1967
    chimp1967 New Member
    hi all,
    I have a little problem with my power steering pump after playing in the snow, oops.
    When i drive normaly the steering heavy but not to bad, but as i drop the revs for a tighter corner i have little assistance from the pump. Parking is a nightmear, i have to keep the revs high and turn the wheel, all the pump dose is grone at me on full lock.
    I have changed the belt hoping that would solve it, but no, afrade not.
    Fluid is clean, with no visable leaks, fluid is bang on the mark.
    With the wheels of the ground i tyied high reving and turning the wheel to full lock left and right. The pump has a slight vibration to it when i placed my finger on the housing. I believe this could be a bearing of some sort, never taken one appart so only gessing but it felt like it to me. The pump also groned as i did this, full lock both sides.
    Ihave looked on the net for one, but without a part number (audi will not give it to my), its hard work trying to get the right one.
    I have also here`d i could get one from a vw jetta or golf, is this correct ?
    Any help please.
  2. ian bleakley
    ian bleakley New Member
    hi i did the same thing in the snow last year lol it ended up be the pump i had to take it off to get th part number as there is a few choices once i fitted the new pump i had p.a.s again hope tis helps.
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    have you checked the fuild level? If it's low it can make the steering heavy
  4. rossbrownlee
    rossbrownlee Ross_S4
    719
    Call another dealer, give the parts guy you chassis no and ask for the part number. first guy sounds like a d*ck. I have never had an issue like that with the parts guys up here who are always helpful.
  5. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Mate, google is your friend.
    Let me google that for you
    The first link will give you the answer you need. An ASN link as well.... :)
  6. Welly
    10,696
    127
