Power steering pump failure?
quattro1 Feb 2, 2011
  1. quattro1
    quattro1 Member
    639
    Hey guys
    Just pulled into my road and as i turned into my space my steering went mega heavy and smoke came through the blower vents with a buning smell! Had a quick look and the aux belt is still intact so im guessing its the pump, is it a driveway job or am i best off putting it in a garage?
    Cheers in advance :bye:
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Its possibly the metal pipe that has gone, very open to the elements esp the bad winter we have had
  3. quattro1
    quattro1 Member
    639
    Which pipe is that mate? Down behind the passanger wheel?
    Cheers :w00t:
  4. s3dave
    10,110
    736
    yes it goes down there then across the engine by the rad and back again, the other one is on the rack itself,
    if it is leaking by the passenger wheel it connects there to some rubber pipes
  5. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    could be worse mine did this without the smoke... booked into a VAG specialist and it turns out it's my steering rack that's leaking power steering fluid... 4 hours labour plus a new rack! :( Gutted. Hoping my pump will be ok despite screeching like heck when it ran dry. :(
  6. woody.dub
    woody.dub Member
    98
    Ive just fitted a new pump on mine, but this was due to fun in the snow lol
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Not normally a pipe if there is smoke being produced. I know, I've cracked numerous PAS High pressure lines.
    Check the PAS reservoir for the fluid level to see if it's empty. If it is, fill with fluid and check for leaks.
    If no leaks, pump is likely.
  8. Welly
    10,696
    129
    Should be OK - mine has seen this a few times. It's not at it's best I admit now, but it has run dry 3 times...
    A bit noisy, but still works.
  9. s3dave
    10,110
    736
    Yeah i was thinking it could have pissed all over the exhaust if it happened while he was driving
  10. quattro1
    quattro1 Member
    639
    exactly the pipe you said it was dave, what a bitch that is to get off! £40 for a new one and im back up and running but i think my pump has seen better days, its making a little squeeky noise on idle now, guessing from being run dry for a minute or two :crying: stupid pipe, cheers for the help again mate
  11. s3dave
    10,110
    736
    No worries glad your sorted, they are a bit fiddly to get on and off £40, wasnt too bad....
  12. sportstractor
    sportstractor Chugger
    2,709
    The pumps are quite hardy. Mine ran for a while with low fluid because my cooler pipe also broke. Just make sure you keep checking the level as it will drop while air escapes. Also make sure you use correct fluid, apparently standard stuff is no good.
  13. S3PEG
    S3PEG Member
    101
    What's the best fluid to use?
  14. s3dave
    10,110
    736
    Audi VW hydraulic CHF 202 ,
