Power steering pipe
Jacko4130 Mar 4, 2009
  1. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    Just bumped my s3 into a ditch and have smashed the bumper and power steereing pipe, anyone got a power steering pipe or know a part number?
    Its the long black steel pipe that comes back on its self and is bolted the the pipe between the two front inter coolers.
    Anyone?
  2. jim s3
    jim s3 Member
    321
    i might just have one any chance of a photo of bit you need as i had to buy a second hand one but only needed a little part of it, got the rest sitting in my garage
  3. themanthatcan
    themanthatcan Member VCDS Map User
    661
    It's a metal pipe so I'm not sure you're taking about the same thing?
    Sounds like it's the high pressure power steering pipe you've damaged. I had this replaced on mine about 6 months ago as it was leaking. Part number is 8N0422893N and it was £140+VAT!
  4. Jacko4130
    848
    £140+vat :ohmy:
    Breakers yard here i come
    Jim - its a steel pipe around 24" long and it does a u turn on its self, Will remove it in the morning and get a photo up
  5. themanthatcan
    661
    Yeah not cheap at all! Bear in mind that because they're metal they do corrode over time and start leaking like mine did. It's quite a common VAG problem from what I've read. It might just be worth investing in a new one to save you the hassle of having to replace it again further down the line. Depends on your plans for the car I suppose!
  6. Jacko4130
    848
    Depends on what they want for one at the breakers, if its more than £30 i'll get a new one, if not i'll chance it.
  7. themanthatcan
    661
    This is the only pic I have of the pipe on my car..the newest looking pipe in the pic with the sensor going into it. That bit is in front of the engine block, just below the a/c compressor; are we talking about the same pipe?
  8. Jacko4130
    848
    No looks like a different pipe, mine runs along the bottom of the front bumper and comes back on its self
  9. jim s3
    jim s3 Member
    321
    Yeah think I have it will look tonight I got it from breakers yard
  10. Jacko4130
    848
    Any chance of looking now? Could come and pick it up asap, have just removed the old 1, will upload a pic in a sec
  11. Mr.G
    Mr.G Well-Known Member Team Sepang Audi S3
    1,434
    228
    If you are stuck then PM me i have access to someone who's breaking a 47k S3.
    G
  12. Jacko4130
    848
  13. jim s3
    jim s3 Member
    321
    I'm on the way home as we speak so will let you know in about half hour
  14. jim s3
    jim s3 Member
    321
    Yes mate I have got one pm d
  15. Jacko4130
    848
    Jim your a god, hope to see you in the morning
  16. jim s3
    jim s3 Member
    321
    no problem mate i will be at the prison from 730 just give us a bell
  17. Jacko4130
    848
    Might be the missus that turns up as i have work i think, will ring you and let you know anyways, she will bring the beers if i dont. cheers man.
