Power Steering Leak
Lemon S3 Feb 19, 2013
  1. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I've had a leak for a while now which takes a couple of days before it needs to be topped up again. I've had a good look and can't see where it's coming from, I've even left a big piece of cardboard under the car to catch any drips to narrow it down but not a single drop. I've even tried the stop leak stuff but didn't make a difference.
    Was wondering are there any common places for it to leak from, if any?
  2. <tuffty/>
    20,767
    3,650
    Almost always the pipework in front of the engine... comes from the pump into a flexi hose then back to a hard hose that acts as a cooler... pretty much all PS leaks stem from that pipe... replacement from VAG is 150 quid or more from memory but others have had the flexi replace by hydraulic specialists for less than 50 quid... assuming the leak isn't from hard pipe corrosion...
    They normally leak on the flexi joints
  3. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    459
    55
    I have the annoying power steering leak. i havent found the leak yet, but just wanted to check with the diagram below is it usually number 5 or 7 flexi's that leak? or failing that the metal cooler part number 6?
  4. <tuffty/>
    20,767
    3,650
    Number 4 :)
  5. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Either 5 or 7 leaked on mine, can't remember which one.
  6. StaceyS3
    StaceyS3 Well-Known Member
    2,487
    466
    Number 4 went on mine and was the hard pipe that had chaffed its way through, oem one was around £300 iirc so got the whole thing made up by a mate at a hydraulics firm for £80 ;)
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    No 6 is the big one that is open to the elements , i got my refrigeration guy to copy it out of copper tubing, and its been fine since..
  8. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Cheers for the help guys, looks like it's going to be expensive and a pig to do. Joy
  9. Crazypete00
    459
    55
  10. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    170
    Mine was number 6 also. I did get a replacement from the stealers due to wanting something to fit right and get the car working again asap.
    When i had a slight accident using an angle grinder removing my downpipe and nicked another power steering pipe but this one was stainless steel and connected by banjo fittings. I managed to get the hole repaired at a local metal fabrication place for £5 so that worked out ok.
  11. Crazypete00
    459
    55
    Well replaced section 6 and looks like I still have a leak. Number 4 is pretty badly corroded but can't see any leaks on it, think it might be the 2 flexi joints, anyone know how much they are to replace and how do I get them off?
    and how much fluid does it take to completely refill an empty system? I had to flush the pink stuff out and replace with green, it's taken 2 litres and not up to the min line on the dip stick yet
  12. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,171
    214
    I recently replaced number 6 on my build and was circa £50.00 + VAT from my local TPS.
  13. CLSmooth
    CLSmooth Member
    34
    Any idea where to get the flexi tubing from as I have a leak on one of those. The inner rubber has split and its leaking through the jubilee clips?
  14. Gops
    3,188
    647
    I replaced 6 recently, £65 inc vat. It's the oil cooling pipe and its prone to leak
  15. TwinCamMan
    TwinCamMan Member
    84
    No 6. went on mine too, made my own from copper pipe and painted it black. Perfect ever since and you'd be hard pushed to spot that it was made from copper pipe.
  16. Jay 01 s3
    Jay 01 s3 Member
    124
    9
    If you don't find a leak try the tie rod boots I couldn't find mine for ages, done the whole cardboard thing and found boot full of oil
  17. Munch
    Munch Member
    256
    23
    Mines leaking from 16, but only slightly, haven't checked any where else yet
  18. L55DSW
    L55DSW Member
    39
    Hi guys, help please i have a really bad leak and its the pipe next to the gearbox, thats why its leaking its been rubbing on the gearbox, which number is the pipe i need?? is it 7?? i cant tell from the diagram sorry.....
    or it maybe 5..????
  19. s3dave
    10,110
    736
    Thats a fairly impossible to answer question mate without seeing it, take a pic?
  20. L55DSW
    L55DSW Member
    39
    Sorry mate, ill get a pic afterwork and post it..
  21. L55DSW
    L55DSW Member
    39
    Sorry never got round to a pic, it was my steering rack that had broke, new one fitted now so skint but happy ha
  22. quattrokid
    quattrokid Active Member
    232
    90
    Guy... found this thread so you'll see it under new posts :)
