Power Steering Fluid
mugglesquop Feb 12, 2010
  1. mugglesquop
    mugglesquop Member
    62
    Hello.
    does anyone know which oil i need for the power steering? on the tank it says about using Mineral Oil.
    Thanks :readit:
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    i used genuine audi stuff about £7 for a litre if i remember correctly
  3. Matt82
    Matt82 Active Member
    2,365
    what he said. not worth putting the wrong thing in
  4. mugglesquop
    mugglesquop Member
    62
    Do you know what the spec/type is?
  5. Matt82
    2,365
    then ask yourself what happened to all the old stuff cos a leak is going to have to be fixed
  6. mugglesquop
    mugglesquop Member
    62
    i'll keep and eye on it. its not quite down to the minimum mark. it hasnt lost any since i've had it (2 months)
  7. aragorn
    18,036
    725
    You want "CHF11S"
  8. mugglesquop
    mugglesquop Member
    62
    that is a synthetic oil though. It says on the tank to use Mineral Oil only... or does it not matter?
  9. aragorn
    18,036
    725
    Its a "synthetic mineral" oil.
    Audi G002000 = Pentosyn CHF11S
    It used to be CHF7.1, which was pure mineral, but audi superceded the same G002000 part number to the newer chf11s type, so if you buy it from audi your getting chf11s anyway.
    http://www.blauparts.com/audi/audi_fluid/audi_hydraulic_fluid.shtml
    The important bit quoted here:
  10. mugglesquop
    mugglesquop Member
    62
    ahhh i see.
    brilliant, thanks very much :icon_thumright:
  11. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    do you have a engine pan fitted (plastic thing under the engine?
    run your finger between it and the lower edge of the bumper on the left hand side of the car.
    bet you it is a bit sticky.
    I have the same leak.
    Lower PS pipe connection where it goes from rubber to solid lines.
    just needs a jubilee clip as it currently has a crappy "use once" clip
  12. mugglesquop
    mugglesquop Member
    62
    i will check, but i had the pan off to do a oil change the other day, and it was all clean then (as far as i can remember).
    think its just the fact that its 13 years old. i only checked it as it was due a Inspection II. in the 2 months i've had the car it hasnt gone down any.
  13. jcb
    4,132
    13
    it won't be on the pan it is more likely to be on the bottom curve of the bumper.
  14. mugglesquop
    mugglesquop Member
    62
    will have a look this afternoon, cheers :icon_thumright:
