power steering fluid
Rutter Apr 12, 2009
  1. Rutter
    Rutter Member
    55
    having never owned a car with power steering i could do with some advice. 1) am i right in thinking the resevoir is the small tank to the front right of the engine bay, labeled "hydrolic fluid". 2) if so it says to use only mineral based hydrolic fluid, is all power steering fluid mineral based?. im at my girlfriends at the moment and have noticed that the (possible) power steering fluid is below minimum, we have some fluid here but it doesent state if its mineral based or not, will it matter?
  2. Siena
    Siena Active Member
    2,626
    Please don't be tempted to just put in regular PAS fluid!
    Seal failure in the pump and rack would result, with major leaks.
    If the pump isn't noisy, it's still ok to drive, till you get the right stuff.
    This is what you need:
    http://www.deltavag.com/mineral-hydraulic-oil-p-88.html
  3. Rutter
    Rutter Member
    55
    it kind of "hums" when i lock the wheel, im guessing that a bad sign?
  4. Siena
    Siena Active Member
    2,626
    A slight change in pitch when turning the wheel lock-to-lock is normal, low fluid will cause more of a groan.
  5. Rutter
    Rutter Member
    55
    oh thats ok then, theres not groan as of yet xD, il have a look in halfords tommrow see if i can get some of that mineral oil, im going to devon next week so i cant risk a late delivery if i order online =/
