I
imported_kbininger
Guest
My daughter's '96 A4 2.8 has a power steering fluid leak. I can see it under the back of the engine, but not the source. The area around the reservoir is dry and clean, as is the pump. Where else does the fluid go? I see one line going behind a panel near the left front wheel well, but can't tell where it goes.
Also, reading some posts, I am now concerned because I used ATF fluid to top it off. Did I make it worse? Should I try to drain it and put in mineral oil? /ubbthreads/images/graemlins/confused.gif
