- Joined
- Apr 9, 2006
- Messages
- 11,376
- Reaction score
- 926
- Points
- 113
Hey guys,
I have an ongoing issue with my lambda sensor which meant my EML was on, but im getting that sorted by replacing the sensor soon, however, I noticed that the car was feeling like it was misfiring a little when under load, so I did a scan on the car and it came up with a different error code this time.
16395/P0011/000017 - Bank 1: Camshaft A (Intake): ****** Setpoint not Reached (Over-Advanced)
I have been on Ross Tech Wiki and it shows the below, but im not too sure on what it means.:
Possible Symptoms
Power Loss
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Mechanical Timing not correct, including Chain and/or Belt timing.
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
Check Mechanical Timing
Can anyone advise on what the issue could be and if this is what is causing the missing issue
Thanks in advance
Nilz
Possible Symptoms
Power Loss
Possible Causes
Possible Solutions
Thanks in advance
Nilz
