Power/engine query
TomS38L Dec 10, 2013
  1. TomS38L
    TomS38L Member
    Hi gents,I have a APL engined S3,210 bhp,slowly gathering parts to get more power although a friend has said I'm barking up the wrong tree with this model as to get the power I have the wrong motor unless I'm willing to spend big money,can anyone shed any light on this for me and point me in the direction of which one is best for gains,I'm presuming it's the bam but any guidance appreciated,I have a cx racing front mount ready to fit,I've decatted it already and have a miltek on order but if I'm wasting my time I'll keep the parts and get a better base model,cheers gents.
  2. <tuffty/>
    21,975
    4,248
    LOL... sorry but your mate clearly knows very little about 1.8t's...
    the APY motor is as good as any... Welly (an ASN member) ran his at over 400hp...
    I think you would be best to elaborate on your power goals and what sort of kit you are accumulating... there are plenty of build threads for S3's on here at varying levels of power and modification..
    What power you are after and how deep your pockets are will determine where you go tbh...
  3. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,188
    Your friend is wrong.
    Keep at it. What are your plans?
  4. TomS38L
    TomS38L Member
    Great news! Was a bit gutted there as it's a great little honest car and got it for a bargain,I'm would like 300-350bhp if I can, I know I'm going to need bigger turbo/injectors etc but as I say I'm gathering parts at the moment...what would you recommend I get??
  5. <tuffty/>
    21,975
    4,248
    This is worth a read...
    http://www.audi-sport.net/vb/a3-s3-...5-off-bills-few-tweaks-so-weve-been-busy.html
    Basically you will need...
    decent FMIC (check FAQs sticky... big FMIC thread on there)
    Hybrid K04 (Beach Buggy Turbos)
    Injectors (Bosch 550's are the current ones of choice)
    3" DP (Relentless or Pipewerx generally)
    Exhaust manifold
    Badger5 TIP
    Rods (rifle drilled)
    Custom map from Bill (Badger5) or Niki (R-Tech)
    There are a few other notable threads of course... a search will help you...
  6. chaz20vt
    chaz20vt Member
    428
    21
    For 300-350ish bhp you would need
    BBT hybrid
    550cc injectors
    Remap
    Rifle drilled rods(plus obvious parts to fit these ie bearings head gasket)
    Uprated manifold (either relentless or wait for bill after Christmas)
    3" downpipe and either sports cat or decat
    Cat back system
    B5 3" tip
    Intercooler(welly cooler)
    Jetex filter or summin not oe
    Probably more but that gets you started
    You need deep pockets for these cars to make them stay reliable and quick
  7. TomS38L
    TomS38L Member
    Thanks chaps I appreciate it's going to cost,and I'm not going straight at it with a pocket full of cash will be over time as is the situ with everyone bitten by the mod bug,just needing direction as 1.8ts are relatively unfamiliar to me as always had beemers but love the little audi :)
  8. badger5
    9,641
    2,073
    your friend thinks this why?
  9. badger5
    9,641
    2,073
    makes me think........ whats worn out on it and needs replacing to make it a sound tuning platform first
    confirm its healthy first... power, compression, leak down, health check... etc
    Then you know what you are basing your desires off..
    <tuffty/> likes this.
  10. TomS38L
    TomS38L Member
    Was slight front end damage,literally small dent in wing and cracked bumper,have replacement parts just not fitting till fmic is installed,also as for health check I've serviced it and changed cambelt,water pump,tensionor and thermostat,zero codes on vagcom.
  11. TomS38L
    TomS38L Member
    Also did a wot run,all was shipshape
  12. <tuffty/>
    21,975
    4,248
    Need to do a compression test and leak down test too... when you do the rods check the bores...
  13. TomS38L
    TomS38L Member
    Leak down test.....what's that then??
  14. <tuffty/>
    21,975
    4,248
    Its a test to see how well the cylinders retain pressure... there maybe enough of a seal to provide a decent compression test result but compression is a peak hold kind of test and not a true indication on how well a cylinder on compression stroke can retain the pressure... leak down tests that
  15. TomS38L
    TomS38L Member
    Ok ideal I'll get that sorted,thanks a lot
