Power cable route
k3v Feb 21, 2009
  1. k3v
    k3v New Member
    14
    Sorry if this is in the wrong section, thought Id get more help here.
    I want to run some power cable from my battery to my boot, whats the best way of doing it through the firewall.
  2. chill14
    chill14 Newbie
    79
    What is it for? If its for a power socket in the boot, then I'd use the fuse box in the dash. There is an allocated fuse for a rear power socket. Just need some auto power cable and repair wire 000 979 225 to connect it to fuse box. This is what I have done. I use it when going camping to power the electric coolbox.
    If it is for an Amp etc then I'm not sure, but I'm sure some one else will be able to point you in the right direction.
  3. kaz219
    kaz219 Active Member
    1,808
    If your A3 is a DSG, you can use the hole for where the clutch should be - i squeezed some 0 gauge wiring through there....
