Potential 1st Time A3 Owner Looking For Advice...
Jimdebob Feb 18, 2010
  1. Jimdebob
    Jimdebob New Member
    Hello people, im currently looking for an Audi A3 1.8T sport (preferably) and thought you guys would be the best people to ask about things to look out for and pay attention to whilst buying one (potential common problem areas eg. water pumps, turbo's, electrical problems etc!)
    New on the forum and would really appreciate any help you knowledgable forum veterans could give!! :icon_thumright:
    Cheers in advance!
    James
  2. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Hi James,
    Welcome to the site :icon_thumright:
    The main things to look out for are a full service history, its not got to be a full Audi history but it helps. The 1.8T will last a long time as long as its had regular oil changes :)
    When we're on the topic of the engine you want to make sure the cambelt and waterpump have been changed. The thermostat is also a common fault as is the temp sender. You should be able to spot any issues once the cars warmed up. If the temp needle doesnt stand straight up after a drive then the thermostat could be goosed, if the temps up and down a lot it could be the sender thats ranted. Both easy enough fixes but I'd be looking at the engine oil carefully and smelling the expansion tank to make sure the engine hasnt been cooked by someone not getting the problems sorted.
    Keep an eye out for any smoke under load or idle when you drive it.
    Common faults apart from the cooling system can be coil packs and the MAF, these are common but not major issues. If a coil pack is on the way out it'll have a rough idle and might be a bit hesitant when you throttle up. The MAF might cause similar issues too.
    Listen out for clunks when driving over bumps etc, antiroll bar bushes tend to go at about 70K miles.
    Make sure all the electrics work
    Make sure the red LCD in the dash (DIS) works properly so you can make everyone else on here jealous as they tend to fail (not mine though :) )
    Volume knob on the Audi Concert Stereo can develop a fault (no major biggy though)
    Look out for a good late facelift model with the one piece headlights. These have a revised interior and are seen as a bit more desireable.
    You should be able to pick up a good one with leather, BOSE, climate etc but it might take a bit of looking.
    If anyone claims a car is remapped or has any 'mods' then get them to back them up with invoices etc. A good service history and folder of invoices is a sign of a well looked after car.
    I'm sure I've forgotten loads but someone else will come along and fill you in.
    Oh and make sure you get a 3 door :)
    Tom
  3. finesse
    finesse Active Member
    2,805
    A3tom, what signs does the expansion tank show when an engine is knackered?? Coolant colour? smell?
  4. A3Tom
    3,504
    14
    You're looking and smelling for any oil or fuel on the cooling system...meaning head gasket failure. Could be caused by a cooling issue leading to a very hot engine (warped head).
    T
  5. A3Tom
    3,504
    14
    Oh, and it doesnt mean the engines totally knackered, just a failed head gasket.
