Post your recommended tyre pressures here
Staz Jun 26, 2009
  1. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    66
    The question of tyre pressures comes up pretty regularly so I thought it was time we made a thread dedicated to it. If it's a good thread then I'll post a link to it in the FAQs thread.
    All I would like is for you to put the car type & engine, wheel/tyre size (unless it's obvious like on the S3), the front and rear pressures you are running and then a remark about that setup if you like.
    Please don't make any comments or ask questions, you can ask them in another thread.
    I'll start:
    '08 S3 3DR (standard wheels)
    Front 38 PSI Rear 34 PSI.
    I tried a few pressures but this setup gives me a good balance of grip when running hard and comfort on the long runs.
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,455
    594
    33/34 all round for me usually
    235/35/19 tyres
  3. Spin140
    Spin140 Well-Known Member
    2,196
    186
    225/40/18 GSD 3 Ass' Standard S3 2009 Alloys - 37/33 - for track events increased to 40/37 lb.
  4. AuldReekie
    AuldReekie Member
    770
    225/40/18 Goodyear Assymetrics on standard rims 39/32.
    Slight hijack: what does the M&S mean on the tyre pressure chart?
  5. pluves1
    pluves1 Active Member
    725
    133
    43
    Staz
    Might it also be an idea for folk to say what they use to measure the pressure given that a lot of garage forecourt gauges are inaccurate?
    I will add my details when I get my hands on the car!
  6. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Tyre fitters set mine to the ones on the fuel filler flap.......erm, whatever they are....(will check and post later)
    cheers
    Paul
  7. Staz
    6,206
    66
    If you're not 100% that your pressures are what you think they are then don't post them :icon_thumright:
  8. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    35 psi all round
  9. Scott
    Scott Well-Known Member
    1,306
    126
    old thread bump - but something which may be useful to others. (since it's somewhat "official" as it's linked in the FAQ)
    currently running 39 psi front and 36 psi rear, but will be messing with these when new tyres are fitted
  10. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,267
    163
    Follow the directions in the fuel cap lid ! works for me ie: 18" 225/40 38psi/38psi.. ish
  11. KeepItTidy
    KeepItTidy Member
    88
    18" 224/40/18 - 36PSI/36PSI
    Should the front be harder then the rears?
  12. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    Mud & Snow I guess.
  13. AuldReekie
    AuldReekie Member
    770
    :) Thanks Johnny, works for me.
  14. alfiejts
    alfiejts Member
    352
    225/40-18 on a 2.0TDi - 33F 30R, as per the fuel flap.
    I've tended to run at about 10% higher than that for most of the last couple of years (mainly because others on this forum were suggesting they were using higher pressures), but my tyres have worn in the middle, suggesting that I was running at too high a pressure, so with a new set of Contis fitted, I've reverted to the recommended pressure on the fuel flap....
  15. Phil_T
    Phil_T Revo Stage 2+ Audi S3
    240
    Why dont you make this thread a sticky at the top of the forum as it gets asked alot
  16. Staz
    6,206
    66
    There are lots of things that get asked a lot but they can't all be made stickies. That's why we have the FAQs thread, which includes a link to this thread.
  17. Scott
    1,306
    126
    Out of interest, would the engine make a difference here, since they are all different weights?
  18. Staz
    6,206
    66
    Yep it makes a difference Scott
  19. Scott
    1,306
    126
    Cool thanks, so am I right in thinking that a diesel would need a higher pressure than a petrol due to the additional weight, or would it need less? It says 42 front 36 rear as recommended pressures for my car inside the door, but I don't like those pressures. I'm currently running 38 f and 34 r and still not convinced...
  20. alfiejts
    alfiejts Member
    352
    My 2.0TDI S-Line with standard 18" wheels has an extra "18-inch" sticker on the fuel flap that says 33 front and 30 rear!
    Others have been suggesting their cars suggest higher pressures, but that's what Audi have stuck onto my fuel flap....
    (And having run 24000 miles on my last set of Contis at approx 35PSI on the front, they're actually worn in the centre of the tread suggesting that they were running slightly over inflated....)
  21. MarkTweedley
    MarkTweedley Member
    144
    I run 18x8 alloys with 225 40 18 tyres and have 40psi all round. At MOT in September my tread was 6.66mm on both rears and 5.56mm on both fronts. Gues I may have this right along with my tracking.
  22. afcjay
    afcjay Member
    437
    225/40/18 running 34 front 32 rears
  23. afcjay
    afcjay Member
    437
    fronts are normally 2-4 psi higher due to the extra weight on the front end so the car is better balenced
  24. MarkTweedley
    MarkTweedley Member
    144
    Ok, so I seem to run quite high tyre pressure then. They look too squishy anything lower than say 38psi to me though or am I just paranoid?
  25. afcjay
    afcjay Member
    437
    40 profiles are quite low tbh.if your not sure just stick with what is says inside the fuel cap
  26. jamessg1962
    jamessg1962 Member
    123
    Also depends on the tyres if you have XL tyres ,extra load, as fitted to some diesels i believe the pressure is increased .
  27. RPB
    RPB Active Member Team Ibis Audi S3 Black Edition DSG
    399
    70
    On my 2011 S3, the door sticker says for 3 ppl and light luggage, 43psi F and 33 R. That's on 225/40/18. Pressures that I am not used to seeing, thats for sure. I had 18's on my Subaru and only went up to 34 psi F. I actually queried it with Audi as I was not used to seeing that high figures.
  28. audicruiser
    audicruiser Audi Heaven
    1,865
    Thats what I run mine at...
  29. andywaddy
    andywaddy Member
    133
    What was the outcome to your query with Audi? Did they say they were the correct pressures to be used?
  30. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    Does anyone on here who runs 19's have any recommended pressures. Don't fancy running 43 psi in the fronts as my teeth will fall out.
    Running 36psi front 33 rear at present.
    If anyone on here with an RS3 could check the prescribed pressures in their flap or handbook I'd be really grateful.
  31. Shadowman
    Shadowman Active Member
    592
    43
    I don't think you are too far away Warren....obviously haven't got an RS3, but I run 36/34 in my 225/35 19's on my S3 BE sportback and it seems about right....certainly no uneven wear when I took the wheels off to put on the winters a month or so ago, and the ride/handling is spot on for me.
    Hope that helps.
  32. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    MY2011 S3
    225/40/18
    38F 33R
