Post Remap Question
Smiffi Mar 25, 2013
  1. Smiffi
    Smiffi Member
    156
    Hey fellas,
    Just looking at getting some advice and maybe some reassurance from some of you guys who are running Stg 1 or above.
    My car is an S3 S-tronic, just over a year old, recently serviced and as far as I can tell, in good health. I decided to take the plunge and fit a Neuspeed P-flo CAI and was pleased with the results. Lots of sucking noises and a small amount of DV on lift off.....all good. I then ordered a Shark Stg 1 map and STS and installed the performance map. I went for a spin and noticed that (other than a big performance increase) when the revs are going through the 3-4k rpm range, I get a sort of flutter noise. It's like lots of small DV noises that happen really fast (psst psst psst psst). I must stress that this is while I am still accelerating, not on lift off.
    I've contacted Shark and they confirm they have issued the correct map for the S-tronic and have suggested it could be a characteristic of the P-flo. My worry is that there is a leak somewhere and I could be causing damage to the turbo if it is some sort of surge.
    Has anyone else on here found the same results after a remap with a P-flo fitted, or indeed any other CAI? I plan on taking the P-flo off and re-fitting the standard engine cover/air box to see if the noise is still there.
    It'd be great if someone could share a little advice on anything I could do to check for problems. I have checked for codes using the STS and found nothing.
    Cheers in advance fellas
    Smiffi
  2. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    Personally your doing all the right things. Get the P-Flo off and get the original back on. I have heard afew people binning the P-Flo for various reasons. The Shark Stage 1 remap is IMO one of the best around and thats not beig biased as Im a dealer. I have tried numerous remaps from the top companies and for overall reliability and driveability it wins hands down. Out of all the S3's I have mapped not one has had any problems and afew of them have had other tuning mods done such as CAI's, twintakes so see how you get on with the original fitted and report back with the results.
  3. GuyJ
    GuyJ Member
    58
    13
    Could this not be a faulty Diverter valve causing this?
  4. Smiffi
    Smiffi Member
    156
    Cheers for your thoughts Brodster. I'll see if I can get it off tomorrow and report back.
  5. Smiffi
    Smiffi Member
    156
    GuyJ, my car is a 2012 so has the Rev D diverter valve fitted which I believe are supposed to be really well made and reliable. I will look into replacing it if the noise I still there once the CAI is off.
  6. Smiffi
    Smiffi Member
    156
    Just a quick update, when I took the factory air box off originally I noticed it was quite oily around the big pipe going to the turbo. I take it this is why people fit catch cans? Or could this point towards a problem?
  7. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,253
    586
    Nothing wrong with your car. It is slight compressor surge that you can feel, as the S3 turbo has a larger compressor in relationship to the exhaust housing. The only way round it is to cap the mid range boost or change turbo.
    Rick
  8. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I have SHARK Stage 1 with Milltek TBE but stock air box and havent noticed any untoward sounds.
    Sounds like a CAI issue.
    Car is also DSG btw.
    Good luck
    Paul
  9. Smiffi
    Smiffi Member
    156
    Hi Rick, thanks for you post. I take it you have you come across this noise before?
  10. Rick @ Unicorn Motor Dev.
    1,253
    586
    Yes, many times. The compressor flows a lot of air - upto 400hp worth and yet spools up very quickly. This is due to the small hot side which means that too much air flow is produced low down the RPM range where the engine cannot consume it. As a rule normally map to just below this surge line unless a customer wants all out.
    Rick
  11. bazs3
    bazs3 New Member
    17
    10
    Same thing has happened to mine 2012 but manual been running stage 1 fine for a good few months got the amd cai kit fitted within a few hundred mile engine light came on with code p2177 running lean so flashed it back to original map running fine now !!!!!!
    Got a service due in the next fortnight so going to wait and see what audi say and take it from there .
    just means might have to forget about stage 1 and go for stage 3 instead hahaha ;)
  12. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,062
    100% normal. It's what they do.
  13. mjr901
    3,595
    1,062
    38 seconds into this video is the noise your hearing I should think.
    Yes different car, but running gear is essentially the same.
    It is normal. :)
  14. mjr901
    3,595
    1,062
    I've done 20k with the P-Flo. Very happy with it, bar the heat-soak issues as its black...and metal....so design is a little poo in that respect.
    But its up to stage 2 no problem and 340bhp.
  15. H17YD L
    H17YD L Active Member
    383
    76
    I asked the exact question last week and got all the replies I was hoping for. It's normal!
    I'm running stage 1 and neuspeed intake.
  16. Smiffi
    Smiffi Member
    156
    That is pretty much the noise I get mate. It must be a p-flo thing as I've never heard it on any video with any other CAI.
  17. Smiffi
    Smiffi Member
    156
    Rick, if its a surge can't that harm the engine? I'd have thought it would have been mention a lot more as the Shark Stg1 is a generic map isn't it? Maybe it's just the P-flo that vocalises this surge? That's 3 people on this thread with it and all have P-flo fitted.
  18. mjr901
    3,595
    1,062
    A friends Edition 30 Golf stage 2+ with ITG makes it. it's not just a P-Flo thing for sure.
  19. Smiffi
    Smiffi Member
    156
    That's a shame cos it sounds a bit strange. I take it your car does it too?
  20. mjr901
    3,595
    1,062
    yup, from the word go.
  21. Rick @ Unicorn Motor Dev.
    1,253
    586
    The amount of surge here is probably going to have minimal effect on turbo life, but I can't quantify it.
    Anything that frees up (read: makes louder) the intake system is going to amplify the sound.
    Rick
  22. Jonse
    Jonse Active Member
    446
    49
    Hi All i get this aswell. I dont have a remap but have the revo air intake and also a milltek cat back. I was hoping it would get fixed with a remap but doesnt sound like it :(
  23. Jackie Brown
    Jackie Brown Member
    155
    22
    Remapping your car will not get rid of an induction noise..
    Does anybody have Rolling Road figure 'before' and 'after' with an induction kit please? Just for my own interest. Cheers :D
