Possible traction control issue?
stevewushu Dec 31, 2011
  1. stevewushu
    stevewushu Member
    109
    My S3 seems to be losing serious traction around bends especially in the damp. And the traction control light flashes on when I do do.
    The ESP button is on so I'm assuming that there may be an issue with it?
    Anyone had this prob also?
    Didn't have this prob with my previous pre facelift S3 before, and not when I purchased this one (x-reg) 6 months ago.
  2. jezzy
    jezzy Member
    768
    Hi
    im having the same issues as yourself.
    my tc light keeps flashing in the wet when i put my foot down or in and out of corners.
    In the dry my car is fine, it grips well and the rear wheels cut in when i try to wheel spin.
    I think my problem is rubbish tyres. they are kendra ****. they were on when i got the car.
    Im quite happy to continue till i can afford a decent set.
    i aint a mad man trying to break records around my local area.
    hope this helps
  3. AARON77
    AARON77 Well-Known Member
    1,324
    31
    Turn the traction control off ;)
  4. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    Lol was going to suggest that,
    The traction light flashes to say its working and cutting the power so your car is fine. Try better tyres as suggested or just take corners at a reasonable speed lol
  5. stevewushu
    stevewushu Member
    109
    Yeah the tyres are cheapo ones, and I usually drive sensibly it's just that on occassion I have wanted to see where the cars cornering limit is (when it's safe to do so), and that's when I found it sliding unusually more than normal in damp conditions.
    But if the TC light flashes on when it happens at least I know it's working!
    Does it make much difference that I have 18's on and lowered at bit?
  6. <tuffty/>
    21,781
    4,165
    ESP is not the same kinda 'driving aid' that cars like Evo's etc come with... it can't fight the laws of physics either... if you have **** tyres you will find a ditch... its probably the ESP that has saved you so far with cheap tyres on tbh...
  7. stevewushu
    stevewushu Member
    109
    Yeah by the sounds of it the **** tyres are the only culprit. Like I said, in the dry it grips like it should.
    Time for a change!
    Thanks for the info on TC guys.
