Possible power loss
duane Jun 29, 2005
  1. duane
    duane Member
    142
    My car came back from it's service today, when they did a diagnostic check it came up with the following code: (17963) charge pressure-upper limit exceeded-engine.
    My car has been re-mapped by A.M.D. The point i'm getting at is that since getting my car back today, it doesn't seem to have the same pick up/boost as it did before it went in!!! Would them sorting out the code possibly have done something to the re-map, or is it just me being paranoid /ubbthreads/images/graemlins/crazy.gif
  2. AndyC
    AndyC Moderator Moderator
    719
    should not have changed it, unless they reflashed the ecu and wiped the map!
  3. duane
    duane Member
    142
    I phoned A.M.D today and they said that it would not have anything to do with the re-map.
    They say that it could be a split hose,diverter valves, or Maf.
    If it was the maf wouldn't it have come up with a different code? I don't think it is the maf for some reason. I'm thinking more air/boost leak???
    Does anybody know anywhere closer to Leicester than A.M.D in Oxford, i could take it to get it checked out and tested.
    The Audi specialist i go to doesn't have a pressure tester. So i asked how he would check for leaks etc.. he said diagnostics check and looking and listening. Without sounding dumb- would that be enough to find a split hose or diverter problem???
    Any help appreciated,
    Thanks, D. /ubbthreads/images/graemlins/beerchug.gif
  4. Jules
    Jules Member
    130
    What audi specialist do you use in or around leicester then????
  5. duane
    duane Member
    142
    I use the lion garage !!! Do you know somewhere else in leicester that is an audi specialist?
    liongarage.co.uk
  6. madvw
    madvw Active Member
    2,489
    hmm, not quite as far, but you could try jabbasport just down the a47 in peterborough.
  7. duane
    duane Member
    142
    Do you know what their hourly rate is? Do they have a web site? I've tried looking it up but can not find anything!!!
  8. madvw
    madvw Active Member
    2,489
