Possible engine mount problem? Help please
moorheadbrian Jun 4, 2010
  1. moorheadbrian
    moorheadbrian moorheadbrian
    9
    I have an '02 1.9TDI 130, when driving normally there is quite a bit of movement in the gearstick when lifting off the throttle and then applying the throttle again. i.e. when throttle is applied the gearstick will lurch forwards a bit then will come back when lifted off throttle. I know it can be normal for a small amount of movement but this is definitley way too much.
    Any suggestions as to what may be wrong? Ive looked through the net and found that a perished snub mount can cause this sort of thing on the petrol engines but there dosent seem to be any info on the TDI's.
    Thanks for the help
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,241
    180
    Mine does this abit, i thought it may be down to the gearbox mount.
