Possible engine mount issue
Stu-pid Dec 7, 2013
  1. Stu-pid
    Stu-pid Member
    84
    After noticing an annoying creaking on the front end and changing all the arms, today I've done the arb bushes and noticed the n/s eingine mount looking abit deflated from the top with red stuff weeping out of the bottom of it. Could this be the creaking issue
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,461
    199
    Possibly, this will be the hydro mount - I believe they stiffen up at higher speeds, the red stuff will be the fluid leaking, so best to replace it anyway.
    I have just replaced one of mine funnily enough.
    May be worth replacing the front snub mount too - they are only a few quid.
  3. Stu-pid
    Stu-pid Member
    84
    Yeah I could see the snub one cracking slightly. Where did you get your engine mount from?
  4. DieselJake
    DieselJake God Mode
    2,169
    383
    I've got B5 RS4 mounts for mine, bought from the dealer (cheaper elseware but for some stupid reason I was rushing), far as I know they don't have the liquid so are solid all the time and will not need replacing, also stiffer so may mean the car shakes more and they don't have the plug for the ECU so will throw up a code in vag-com, but yeah supposed to be decent haven't fitted yet though.
  5. Stu-pid
    Stu-pid Member
    84
    So you don't need a mount with a connection on then. I'll just get some febi mounts then seen as that's what my arms and arb bushes are.
  6. deano1978
    deano1978 different gear
    713
    80
    Has it boight any codes on?
  7. Stu-pid
    Stu-pid Member
    84
    I've only got a code reader not vag-com I will plug it in later. I've not got a eml on
  8. Stu-pid
    Stu-pid Member
    84
    No codes but my reader only reads dtc's
  9. carpetbagger
    carpetbagger Member
    62
    Hi had same engine mount fault on my a6 but when scanned it come up with engine mount solenoid cant remember code
    mount was best part of £200 then labour but when fitted felt smoother
  10. Stu-pid
    Stu-pid Member
    84
    I'm going to change it I've got a shake on tick over that's getting worse plus it's leaking red fluid out of it. Going to change the front snub bush too as that's showing signs of deterioration.
  11. carpetbagger
    carpetbagger Member
    62
    if its bad on idle you wont be disappointed on end result
    Stu-pid likes this.
