Possible boost leak? - Hiss / Air escaping when turbo spools up (2.0 TDI 170)
The_life_pursuit Dec 5, 2013
  1. The_life_pursuit
    The_life_pursuit New Member
    21
    Need some help please. I have a 2007 A3 2.0 TDI 170, which has covered 78,000 miles. The car has just developed a hissing / air escaping noise in 3rd, 4th and 5th gear when accelerating. The noise occurs between 1500rpm and 2000rpm only. I believe it's when the turbo initially spools up under load.
    I took the car to Audi who advised that the intake manifold was the cause and needed replacing, which they did. I picked the car up and the same noise can still be heard, so it went back. Just had a call from the tech who advised they have pressurised the system, and cannot find any leaks.
    (NB - the noise is not the usual 'whine' you get from the turbo, more like the sound you get from a punctured tyre when the pressurised air is escaping)
    Any advice would be appreciated as I suspect Audi will return the car with it still exhibiting the same symptoms.
  2. Sevv
    Sevv Pushing the limits..
    1,324
    120
    check the inlet mani hoses and clamps, along with the discharge pipe, and inlet /outlet to the FMIC , ive seen a few golf tdi coming in having that issue, might wanna check the brake booster too
  3. davc
    davc Well-Known Member Team Glacier Audi S3 quattro s tronic saloon
    648
    651
    93
    Been there before with the same problem, turned out to be the IC exit pipe.
  4. The_life_pursuit
    21
    Cheers Sevv and davc for the advice. Due to pick the car up shortly. Audi have advised they have tested the system with 1 bar of pressure, and found no leaks, and done a visual inspection and found nothing. Will have to wait and see....
  5. dannyjna
    dannyjna New Member
    Mine was the pipe behind the front bumper underneath, think the mrs clipped it on a kerb just clipped back in mines only a 140 tho
