poss misfire cause
audi1664 Oct 27, 2010
  1. audi1664
    audi1664 Audi For Sale
    52
    Alrite guys my audis got a misfire from nowhere, long story short my temperature gauge has been intermittent working and not!
    I got told today by an ex audi mechanic that a poss cause of a misfire could be a temp sender that before telling him the gauge fault!
    Can anyone say if they have heard of this?
    If so where could i purchase a new switch from!
    Thanks for your help guys!
  2. aragorn
    18,544
    865
    New sensor from Audi.
    Doubt it would cause a missfire though. Have your checked all the usual ignition components?
  3. audi1664
    52
    yeah all checked first of all brought genuine set up plugs, and still nothing, its a slight misfire when cold and gets worse the warmer it gets, solus scanner coming up with nothing also no engine management light?
    I used to be a bmw mechanic and in the past have had e30`s misfiring and this was down to the sender!
    Suppose its a £15 gamble!
    Will go to audi!
  4. audi1664
    52
    set up i meant spark plugs
  5. murran
    murran Well-Known Member
    1,545
    39
    youve already started a thread about this havent you? i posted in it....
  6. audi1664
    52
    Yeah I did but that was asking why the misfire this is asking if a temp switch could be a cause!
  7. murran
    1,545
    39
    did you have a look at the injectors like i suggested?
  8. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    if the misfire is present cold or hot then its not a temp issue, could be sparkplug, coilpack, faulty injector...
