Posible to change via vagcom?
Chachi Aug 10, 2013
  1. Chachi
    Chachi New Member
    Hi guys I just bought a 2009 S3 restyling and wants to know how to change a few settings via vag-com
    1) auto window closing for rain
    2) DRL off all the time? In leds
    3) automatically turn the side-view mirrors down when in reverse. (Veg-com settings have been changed but is not working)
    4) Close windows automatically whe inside the car with the lock button.
    thanks ;)
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    1) do you have auto lights/wipers?
    2) just switch your headlight switch to off?
    3) not possible on a3
    4) not possible but just put all your windows up via the window switch?
    Alexthekidd54 and shady-ninja like this.
  3. shady-ninja
    shady-ninja Active Member
    999
    53
    i couldnt have thought of a better answer.
    my alfa 159 TI did all that by the way.
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Hi there. You've been given some duff Gen there.
    1. Not possible on A3
    2. VCDS tweak to turn LED's off.
    3. Possible but you need electrically folding and tilting mirrors with VCDS tweak. Speak to NHN on here. He is the retro-fit guru and the main man when it comes to anything VCDS
    4. The only way of doing this is by pressing and holding the key fob lock until windows raise. Never heard of it being done by the switch on the door.
    NHN will be along shortly to amend and give better advise but that is the gen so far mate.
    Can I suggest that if people are going to give advice then please do so IF you know what your talking about. The replies in post 2 were a lot of rubbish.
  5. rOb_A
    rOb_A Active Member
    1,488
    you tell them Mark :laugh:
  6. Yonner
    Yonner Member
    155
    Not sure about number 1 , think you need rain sensor,
    2, check in central electrics in all the bytes there may be a box to tick
    3, if you have it enabled make sure you have your switch on your drivers door selected on passenger side while you put the car in reverse :)
    4. Hold the lock button in on your key for the windows and sunroof to close , and if you want windows down hold the unlock in for 5 seconds
  7. Chachi
    Chachi New Member
    thanks guys
    1) I have rain sensor but i dont have the byte to tild
    2) I want all time my leds get on even when the switch is off
    3) i have tild in vds mirror with reverse but nothing happends
    please NHN help :(
  8. Chachi
    Chachi New Member
    sory 2) DRL ON all the time? In leds (I WANT ALL THE TIME ON)
  9. Chachi
    Chachi New Member
    Nobady?
