Porsche Cayenne Six Pots
ANDYTQ Mar 28, 2012
  1. ANDYTQ
    ANDYTQ Well-Known Member
    1,185
    106
    [​IMG]Slight difference in size of caliper ,lol.
  2. ANDYTQ
    1,185
    106
    [​IMG] clears my a6 rims with 10mm spacers by about 6-7mm,thank feck lol
  3. ANDYTQ
    1,185
    106
  4. ANDYTQ
    1,185
    106
    Also clears s line five spokes with 10mm spacers [​IMG]
  5. ANDYTQ
    1,185
    106
    Thats the dry run done and the photos for you guys,just got to find some bolts now,mrc hoses look right as well,off to work now,maybe finish off this weekend or next week.cheers Andy
  6. outsideline
    outsideline Active Member
    295
    45
    give this guy a ring mate for your bolts, he supplys everything you need for the conversion and others.
    david brown - 07831275602
  7. ANDYTQ
    1,185
    106
    Just need some 60mm m14 bolts instead of the 50mm ones so not hard to get ,but thanks anyway.
  8. ANDYTQ
    1,185
    106
    Bolts ordered hopefully final fitting next week.
  9. ANDYTQ
    1,185
    106
    Finally fitted, bolts i ordered were slightly too long this time so ideal bolt length seems to be 55mm .Pedal feels good ,just bedding in better high speed testing tonight.
  10. ANDYTQ
    1,185
    106
    Awesome stopping power,still bedding in discs have a anticorrosion paint on them so trying to wear that away plus pads are only standard so how good should these be with ferodos or simular.Really good feel to them no excessive pedal travel,feels like a stock setup but with loads more power and bite.
  11. andymc
    andymc New Member
    10
    so what are the brakes like now youve bedded in any better . just asking because iam going to do mine now .where did you get the discs and have you any part numbers for discs . any help would be appreicated
  12. ANDYTQ
    1,185
    106
    Bedded in so much better;but i will get some better pads soon for more bite.Discs i got from euro car parts.
  13. stuartyp
    stuartyp Member
    59
    hello mate brill thread one question if you dont mind . Will these bolt straight on to my b7 20tdi sline or do i need the s4 hubs many thanks stuart
  14. ANDYTQ
    1,185
    106
    Not sure mine is a s line se quattro which had 320mm discs to start with.
  15. stuartyp
    stuartyp Member
    59
    well done some mesuring and looks like they are going to fit but the hoses are getting to me. My autoparts store tells me that the flex pipes are the same on mine as that on a rs4. So so it the hard pipe that i need to go from the flexie pipe to the calpier many thanks stuart
  16. ANDYTQ
    1,185
    106
    Much easier to get mrc braided one piece hoses for rs4,i know that they do fit,i dont think the standard ones will fit.
  17. ANDYTQ
    1,185
    106
    Will probably get some floating giro discs later on they look too be the best discs available for track use.
  18. ajax1976
    ajax1976 Well-Known Member
    1,279
    656
    I've been gathering all the bits I need for the conversion and pads are the last thing I need. I read that 18z pads over hang the 345 ML disc so some guys use the 17Z pads(330mm disc), Just wondering what pads you're running Andy?
  19. ANDYTQ
    1,185
    106
    Still running the stock pads that came with the calipers i will stick with these until they wear out ,then i'll get some girodiscs 350mm and uprated pads should be a crazy set up then and a lot lighter too.Ml discs are fine for road use but the giros should be much better for track use.
  20. ANDYTQ
    1,185
    106
    If you see my pics pad overhang is hardly anything,but as you say audizine guys say 17z pads are a better match with 18z calipers and ml discs
  21. popes996
    popes996 New Member
    21
    Hi there and sorry for first post being a pedant - for clarity in case anyone else takes on the 6 pot fitment the calipers you have are from a V8 or Turbo not a Turbo S.
    V8/Turbo (4.5l) piston sizes are: 2 x 30 mm + 2 x 34 mm + 2 x 38 mm
    Turbo S (4.5l) piston sizes are: 2 x 32 mm + 2 x 36 mm + 2 x 38 mm
    V8/Turbo total pad area: 428 cm²
    Turbo S total pad area: 480 cm²
    V8/Turbo: Silver (V8) Red (Turbo)
    Turbo S: Red only
    Clears things up if people are gathering parts.
  22. ANDYTQ
    1,185
    106
    Mine are the 18 z calipers from a turbo or so i was told or maybe not lol.
  23. ajax1976
    1,279
    656
    Cheers Andy:thumbsup:
    I've ordered some Cayenne pads but not really sure what ones!! I can't seem to find out what Cayennes, Touaregs etc came with 17z or 18z calipers so just ordered a set of cheap Mintex ones, at least I know either 17z or 18z pads will work!!
  24. popes996
    popes996 New Member
    21
    Cayenne (9PA) came with four different types of caliper
    Black - 3.2l V6
    Silver - 4.5l V8
    Red - 4.5l Turbo
    Red (bigger pistons)- 4.5l Turbo S
    I wasn't trying to be difficult - just if others were looking to do the same mod it helps to know what to look for
  25. ANDYTQ
    1,185
    106
    No problem thanks,mine are off v8 then.
  26. ANDYTQ
    1,185
    106
    Ajax where did you get your mounting bolts from and which did you go for.
  27. ajax1976
    1,279
    656
    I got them from a guy in Poland from another forum, 21 Euros delivered and here in 5 days. I saw some on Ebay for a crazy price (£66) and there was no way I was paying that so was going to fab up my own until I found the others.
  28. ajax1976
    1,279
    656
    Popes, Do you know of piston sizes of other 18z applications?
    I've just nipped out to the garage and my pistons seem to be a bit smaller than any of the other ones you've listed. Pistons were retracted, but a rough measurement of mine are 34mm 30mm and 26mm.
    I'm guessing Touareg as mine weren't silver or red etc.
  29. popes996
    popes996 New Member
    21
    9PA Cayenne (MY04>10)
    V6 system known as the 17" brake
    V8/Turbo known as the 18" brake
    Turbo S known as the 19" brake
    V6 (3.2l) piston sizes are: 2 x 34 mm + 2 x 36 mm + 2 x 38 mm
    V6 total pad area: 384 cm²
    V6: Black
    Turbo S: Red only
    For Caliper part numbers/pads etc see page 222> of the following
    http://www.porsche.com/all/media/pdf/originalparts/en/E_9PA_KATALOG.pdf
    The number in (-) is a supeceded part.
    The dust seal area of the piston has a smaller diameter (to accommodate the seal lip) so the actual piston diameter will be larger.
  30. ajax1976
    1,279
    656
    Thanks mate, good info there!!
  31. popes996
    popes996 New Member
    21
  32. ajax1976
    1,279
    656
    Andy or anyone else running Cayennes just looking for a wee bit advice/confirmation regarding the lines? I'm all bolted up and just have the lines to swap over and bleed tomorrow after work.
    I'm using MRC B7 RS4 lines like yourself and many others but can't find any pictures online that show how the line sits once bolted up.
    Does this look OK and similar to yours or does your elbow point downwards and with a single curve up to where it connects to the solid line on the chassis?
    Lastly, the spring clip thing on the joint between the new line and the solid on the chassis, does it lift off once the joint has been split and then reclips onto the new line before rejoining?
  33. ANDYTQ
    1,185
    106
    Looks simular to my pipe routing i think,i had to fit a washer over the chassis end of the to stop the smaller end pulling through and yes reuse the spring clip.
  34. Broken Byzan
    13,237
    465
  35. ANDYTQ
    1,185
    106
    Hi mark.
  36. ajax1976
    1,279
    656
    Good man, thanks for the quick reply!!
    Any tips for bleeding?
    I'm thinking of swapping one over, then bleeding starting from the inner nipple then the outer one, then doing the other side.
    Bled brakes in the past using the two man traditional method but bought a Gunson easibleed thing to pressure bleed these, not really looking forward to it tbh!!
  37. ANDYTQ
    1,185
    106
    Used the gunson on mine.
  38. ANDYTQ
    1,185
    106
    Did you use modded ml55 discs ie with slight machining in the hub diameter?
  39. ajax1976
    1,279
    656
    Yeah, ECP were selling Pagid ones on Ebay for £38 each with free postage and mate machined them for me.
    All fitted and bled today, The gunson worked a treat, quick and easy!!
    Really over the moon with them, great peddle and very progressive feel to them.
    All in it cost me £520 for 2nd hand calipers, new pads and fitting kit, new discs, new lines and the caliper bolts. If I'd been a bit more patient and held out for custom lines I could have done it for under the 500.
    Thanks for all the help and advice tho Andy, it was your thread that got me hooked on the Cayennes!!
    Need to buy wider spacers if I'm gonna use the Speedlines this summer tho!!
  40. ANDYTQ
    1,185
    106
    Well done i'm glad you are pleased with them and you managed to do it cheaper than me which is a result,my calipers were £500.
