Porsche calipers.
PaulJC84 Dec 13, 2007
  1. PaulJC84
    PaulJC84 Owner
    2,903
    17
    Hi folks just a few questions.
    I know the Boxter calipers fit on the 312mm upgrade discs and the Boxter s and 996 carrera calipers fit on the S4 disks.
    But which ones fit on the 322x32mmdiscs?
    The 996 turbo or the GT3 4 pots?
    What size discs do the cayenne turbo 6 pot calipers need? Can they be used with a smaller disc than say 345mm?
    I ideally would like to still be able to run my 17s even if spacers are needed.
  2. Layerz
    Layerz Member
    144
    Out of interest could boxster calipers and 312 discs be swapped onto my b5 tdi as I got the 288mm vented fronts.
    Or do I need moddified carriers?
  3. PaulJC84
    PaulJC84 Owner
    2,903
    17
    Yeah you would need carriers and new brake lines
  4. PaulJC84
    PaulJC84 Owner
    2,903
    17
    Just to add I have found a company which sells blank bells, carriers and universal discs.
    How would I work out the size of the offest for the bells?
    Then I think it would just be a case of getting them drilled for 5x112 and getting the carriers machined.
  5. Markey
    Markey Active Member
    2,175
    Who are they as i need some carriers for my new brakes.
  6. PaulJC84
    PaulJC84 Owner
    2,903
    17
  7. Markey
    2,175
    Its possible you might get them if you ask the dimensions as they do say universal.
    I hope to have a set of Movit calipers soon :) i really rate them more so than some of the others avaliable.
  8. PaulJC84
    PaulJC84 Owner
    2,903
    17
    Yeah are they not the same as the brembo porsche ones? Should be great.
    What size discs you going to get?
  9. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    buy the time you have bought bells and discs for those you look to be spending £3-400 for discs the smaller than B5/B7 RS4 discs at a lower price. before you have bought fittings and drilled stud patterns into the bells and adapters
    looks expensive. how big are you going?
    this is B5 RS4 (360mm) with Cayenne 4 pot rears on an S4 hub. lots of room for an adapter
  10. PaulJC84
    PaulJC84 Owner
    2,903
    17
    I think the disc size I want is 323mm x 32mm. As I want to be able to keep 17s.
    I was reading on one page that the 6 pot cayenne calipers can use discs between 322mm - 360mm. What you reckon? Would say a 323mm disc hardly go in the caliper?
    I also notice those are the cayenne 4 pot rears above. Have you got the part number? They may be the same as say the boxter s fronts or the older 4 pot GT3 calipers.
  11. Layerz
    Layerz Member
    144
    What is the most simple change and upgrade on discs say I wanted to go upto 312mm.
    I understand the carrriers, new lines needed for the extra fluid 4pots require?
    And if going 312mm upfront, would I need to uprate the rears also for balance as 2/3 or the braking effect (or something like that) comes from the fronts anyway.
