porsche brakes
jimboA3 May 23, 2004
  1. jimboA3
    jimboA3 Member
    336
    If callipers and disks can be sourced on thier own for this conversion on to an a3 , what else is needed and can you buy these parts seperatley? /ubbthreads/images/graemlins/beerchug.gif
  2. excursion
    excursion Member
    740
    Yes you can indeed.
    AmD sell the brackets and bells. £240 last time I enquired.
  3. s8n
    s8n Member
    207
    Does anyone know if there is a kit that allows a bigger disc for the A3/S3 setup? That is, bigger than 322 , maybe something like 355 but still using the 993TT caliper?
  4. dunk
    dunk Member
    770
    firstly, the brackets sold for the s3 will only work with the 993twin turbo brakes - the calipers are very hard to get second hand because every 911 tweaker out there is putting them on their cars. new they are £310 each plus vat
    the disks are about £118 each which represents very good value for money - if you can get 2nd hand calipers they tend to go for about £500 a pair reconditioned, so
    buying the bits new but separately is slightly more expensive than the complete kit from AMD or others
    993tt calipers cannot take disks bigger than the 322mm.
    second hand route will only save you £200 or so IF you can find the calipers.
    i tried to find someone to use the 996 turbo calipers with the bigger 330mm disks, but i could only find one in canada that charges £600 for the brackets and bells...also the disks are about 10lb heavier each than the 993 ones
    you could have a custom set of brackets and bells but the companies need your car for a week or so to do this.
    which leaves bigger brake kits:
    brembo floating kit 328mm very expensive
    tarox big disk kits -not sure
    r32 /tt 3.2 brakes 332mm but single pot sliding caliper about £1000 with all the bits for a proper conversion
    AP 332mm kit approx £1400
    hi-spec do a 355mm kit very cheap but the disk have significant runout, dont centre properly and the number of appalling stories on the net says dont bother...
    ECS are currently working on their stage 4 big disk kit for a3/tt - it isnt on their website but the version for the golf it. it will use their own 355mm drilled/grooved floating disk kits with porsche boxter monoblock front calipers. i spoke to their engineers and the whole setup is ligher than the porsche kit with equivalent stopping power - directional cooling veins, very quiet in use, replacement disks are about $120 whole kit will be a few hundred pounds cheaper than the porsche 993tt setup. maybe wait for this one.
  5. ELIASGK74
    ELIASGK74 Member
    47
    WHAT DO YOU THINK ABOUT 330X30 GALFER(AP)BRAKES?
  6. dunk
    dunk Member
    770
    ecs 355 disks are lighter than the porsche 322mm kit.
    because the radius is larger on the 355, this offsets the smaller pad size of the boxter caliper. - their engineers feel that the kits are comparable in stopping power, but the 355mm look a lot better under 18" or 19" wheels.
    if you are a track day demon, they recommended the porsche kit because it has more mass in the disks and is slightly less prone to fade.
  7. jimboA3
    jimboA3 Member
    336
    so will the 996 turbo brakes fit on an A3 ? with the adaptors of course.
  8. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Thw whole kit will fit just fine.
  9. jimboA3
    jimboA3 Member
    336
    cool,found some on ebay ! might have to be a toss up between the brakes or the retrim ! oooooooohhhh dear!
