Porsche 312mm brake set up
niallh Nov 27, 2012
  1. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    *edit* Weird, I just quoted totally the wrong thing.
    What discs and pads are you running Paul?
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,253
    354
    the LCR calipers come in 2 halves
  3. 16Klappe
    5,795
    1,183
    See my edit, I was miles off and still thought we were comparing the LCR's to the Porsche ones. **** knows how I managed that, playing Forza and typing with half an eye and one hand haha.
    Pretty certain there is a difference between the GT Junior kit and the LCR ones though, in that the LCR ones have an external balance pipe as apposed to internal?
    Has Paul got the GT or the GT Junior kit, because the two are quite different.
  4. Alex C
    3,253
    354
    haha no worries, i was a bit quick on the trigger! Horizon or 4?
  5. 16Klappe
    5,795
    1,183
    4, I bought Horizon....Realised it was for children and put it back in the box ;)
    Jpigs, add me and we'll have a race :p
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Not that weird...... ;)
  7. colicabcadam
    colicabcadam Guest
    all the fighting and arguing, thought i'd state that this is what you call a brake setup........
    anyways, enjoy arguing some more lol
  8. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Im using CRN grooved discs and ( wait for it... ) EBC yellow stuff pads,
    Ive tried DS2500 pads and never felt much diffrent, So before this is slated as the weak link... it must be somethingelse , The fluid has been changed twice and its always been ATE super racing Blue fluid.
    To be honest when i fitted mintex standard pads they worked/ felt as good as any of the others.
    Since i uprated the rear set up the car pulls up alot quicker but i want to sort the fronts properly next.
  9. s3dave
    10,110
    736
    Thats just a toy....
    This is what you want....
  10. S3 Paul
    2,823
    107
    Most if not all th 8L A3/S3's in here arent worth the price of the replacement discs and pads for those.
  11. Prawn
    11,370
    3,234
    GT/Jnr GT, we're all talking about the 2 piece calipers with 323mm discs. I don't know what you're thinking the GT kit is, but the ones that are the same essentially as the LCR's are the jnr GT's.
    Paul: your GT kit is the same as the LCR brakes to all intents and purposes, marginally different caliper, but same pistons, pads, and discs.
    Your problem is pads, and cooling I suspect.
    Forum's always seem to rate Ds2500's, and I'm sure for most people they are ok.
    Not for me though, they're just not good enough. they overheat too easily, and don't stop the car well enough every single time.
    If you're pretty hard on your brakes, which it sounds like you are, then ds2500's won't be for you.
    I've said this many times before, but you really need to try some more extreme pads Paul, like Ds3000's, or carbotech XP8's.
    I currently run mintex 1177's, and they really do pull your face off, much like DS3000's.
    check out this graph of coefficient of friction vs temperature for a range of ferrodo pads:
    Above ~260 degrees ds25000's just fall off a cliff, where ds3000's just keep on getting better and better!
  12. 16Klappe
    5,795
    1,183
    EBC's are your problem I think then Paul; they are actually unsafe. I will never use an EBC product again after some of the things I have seen.
    Just give it a go, I know it's expensive but Prawns brakes physically hurt my face. I know it's a commonly used expression but honestly they make my eyes hurt when he puts the land anchors on.
    I'm currently weighing up my options for the early part of next year, I need discs and pads and think I am just going to jump up to the Brembo's. No point sticking with 312's when I need to spend £200 on discs and pads anyway.
    Also with regards to fitment LCR calipers are 5.5mm different offset to GT Junior calipers.
  13. superkarl
    superkarl MAN OF STEEL
    9,369
    2,367
    what are DSUNO's, and where can we buy them?
    more consistent than any other according to that. initial bite must be insane
  14. 16Klappe
    5,795
    1,183
    Not cheap...
    Ferodo Racing
    Initial bite isn't that great at all -
  15. Prawn
    11,370
    3,234
    look pretty epic don't they? I have no idea what they are though! that graph illustrates exactly why the 3000's perform better than 2500's though, the 2500's get better as they start to warm up, then quickly fade. 3000's take MUCH more abuse, and I think it's heat related fade that's pauls problem.
    I know Bill runs ds3000's on his 600bhp race car, so they can't be that bad!
    Paul, I'd also look into brake cooling if I were you, my inner pads run FAR hotter than my outer pads, and this can be seen in disc wear, pad wear, and the colour of the components when they come off.
  16. S3 Paul
    2,823
    107
    How "bad" are these better pads from cold? remember mine is a daily too.
    DOes it take much to get them to a working temp?
  17. Dani_B19
    9,048
    337
    Paul you need some 2 piece loving in yor life off bill haha, thats what im getting, im goig to be using the lcr brembos with billes 330mm 2 piece disks.
  18. Prawn
    11,370
    3,234
    not bad at all, in any way what so ever infact.
    You read so many things about how people shouldn't use track pads on the road because they lack initial bite, but of all the different track pads I've tried on the road, I've not found any of them lacking in cold bite at all.
    My ds3000's had far more instant cold bite than my standard brembo pads do, even after 30 minutes cruising along a soaking wet motorway in a downpour, they're still razor sharp from the first press of the pedal
  19. S3 Paul
    2,823
    107
    The pedal stays quite hard. Just the car doesnt shed speed very well after the first BIG stop.
    The front discs can take another set of pads im sure of it. So as they arent warped i plan to keep the discs.
    Is Bill the best place to source these Ds3000 pads?
    Do they muller the discs?
  20. niallh
    niallh Member VCDS Map User
    213
    Just to update this thread. Have fitted the LCR's now, the porsche alloys are a tight fit but need some spacers to clear the spokes as was advised earlier. Wanting them refurbed for winter so have taken them off in favour of a set of TT's that I forgot I had in storage, got a few mm of tread left on the TT's so will be buying some new tyres in a couple of weeks
