poor starting
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by samuelt, Apr 15, 2008.
  1. samuelt
    samuelt Member
    May 27, 2006
    383
    Hi all
    when i start my 2002 A4 130 Tdi from cold it usually takes about 2-3 seconds of turning the key for it to start. When it is warm it start as soon as i turn the key. Could this be a fuel priming issue? has any one had this before? It has never not started.
    thank you
  2. Advert Guest Advertisement
  3. jase0851
    jase0851 Member
    Oct 8, 2004
    784
    heater plugs ? i know the plugs on tdi,s come on for a longer interval from cold.my previous tdi plug light on the dash used to come on and go straight of when warm but when it was cold it stayed on for 3 to 4 seconds
  4. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    Jun 5, 2007
    845
    How old is the battery? If its starting to wear out it'll take more time to get the engine going from cold, when its warm its had its charge topped up from the alternator.
  5. arthurfuxake
    Mar 16, 2004
    1,308
    I've also noticed this on mine lately. It is better if I wait for the glow-plug light on the dash to extinguish before turning the engine over, then the car starts pretty quickly. If I jump in first thing in the morning and start the car without waiting for the glow-plugs to warm up, the engine turns over for a good fewq seconds before catching, and there is a puff of smoke from the exhausts too which seems to indicate unburnt diesel.
    Try letting the glow-plugs fully warm up before cranking the engine.
  6. samuelt
    samuelt Member
    May 27, 2006
    383
    THe battery is 1 year old and is Bosch Siver top so should be good! the glow plugs do not stay on any longer if it is -3 or +13.
  7. arthurfuxake
    Mar 16, 2004
    1,308
    Oh!
    Mine stay on longer if it's cold. In warm weather, the light goes out within about 2 seconds. In really cold weather the light stays on for about 5 seconds, and if I crank the engine bfeore the light goes out, it struggles to fire up and there is a puff of smoke when it does finally fire up.
