Poor starting tdi 130
leigh72 Nov 5, 2013
  1. leigh72
    leigh72 New Member
    27
    Hi all,
    I've got a 2002 tdi 130 (103000miles), normally it's a really good starter - as soon as the key is turned. However over the past month it's taking longer to start from warm, sometimes it's takes 3 or 4 seconds with it occasionally taking a few go's of turning the key. It's regularly serviced and had just had new filters , and the only fault code that is coming up is for an engine mount sensor. Other suggestions by friends are injectors and pump clearances. I'm going to fill up at a different forecourt and add injector cleaner to see if that makes any difference.
    I have done a search but it hasn't brought up anything with the same symptoms. Any advice would be appreciated.
    Thanks in advance
    Leigh
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Car battery with the weather getting colder and also possibly dead glowplugs. I had three of mine die and the battery was also weak and had similar symptoms last autumn.
    All replaced and started strong and quickly
  3. pauldazzle
    pauldazzle Well-Known Member
    1,193
    95
    A minimum of 250rpm is needed to start a PD engine, so its worth jump starting off another battery, & if it starts normally then your battery is getting tired.
  4. leigh72
    leigh72 New Member
    27
    Thanks for the ideas, will try jump starting it next time (had a new bosh battery about 2years ago as well) if that fails will check the glow plugs.
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    flick your headlights on before starting and see if that changes anything
    the switch develops a fault in the off position and causes the same problems
  6. leigh72
    leigh72 New Member
    27
    Thanks for the suggestion, I tried the lights and it turned out to be the cause so I'll get a replacement light switch. Glad it's nothing more expensive/ time consuming. Cheers.
  7. stu_m
    1,441
    lol wait till you see the price of a genuine switch!!
    have look on here for the ebay ones they are only about £20
  8. leigh72
    leigh72 New Member
    27
    Just an update, fitted a replacement headlight switch in early December, and everything has been perfect since, so thanks for the replies:icon_thumright:
