poor starting since injectors changed
mm707 Sep 23, 2012
  1. mm707
    mm707 Member
    278
    Hi,
    Anyone else having problems with poor cold starting since the injectors / loom were changed ?
    I am and I'm wondering if there may be a problem with the wiring loom which connects injectors and glow plugs ?
  2. madstaff
    madstaff Member
    105
    Do you mean it takes an extended period of cranking when cold??
    Mine does this but only from time to time.
    I'd like to solve it but as it only does it now and again its difficult to identify the cause. No fault codes stored either.
  3. mm707
    mm707 Member
    278
    yes - it takes too long to actually fire up, only the first time from a cold start - the rest of the day is usually fine.
