Poor radio reception after independent garage worked on car
DWH Jan 4, 2014
  1. DWH
    DWH Member
    50
    I'm looking for some advice please.
    My car, 2003 1.8T Cabriolet, was leaking fuel from somewhere and so I took it to my local independent Audi and BMW specialist whom I have used for several years and always been pleased with the results
    The leak was diagnosed as a faulty fuel solenoid that had flooded a "carbon canister" and then leaked out.
    The car was repaired and left out for me so I could collect it out of hours.
    The car seems to run fine but the radio has not lost all reception, only getting a very faint signal infrequently. The other issue is the fuel economy. I normally get between 38 and 40mpg but on the run home, the trip computer only showed 31 mpg.
    Could the lack of radio reception or economy have been caused by work done to access or replace the fuel solenoid and cardon canister ?
    I haven't been able to talk to the garage yet as they don't reopen till Monday.
    All thoughts appreciated
    David
  2. dares_uk
    dares_uk Member
    169
    Hi
    Sorry, im not able to help,.
    But i do have an 05 1.8t Q Cab,
    and i too have **** radio reception sometimes,
    I believe there are two ariels in the boot lid some where.
    So wouldnt of thought they done anything to them,
    Might just be a common issue. ??
    + "I normally get between 38 and 40mpg but on the run home"
    Thats good, is yours a quattro ?
    i seem to get 25mpg average,30 if im good/light footed. ??
    Which i **** IMO, but i know it is a heavy car.
  3. DWH
    DWH Member
    50
    Hi dares_uk
    No mine isn't a quattro, it's totally standard although I have had cruise control retro fitted.
    The economy is slowly coming back, 35mpg indicated today. I do drive it steadily with only the occasional burst. I do think it would benefit from the later 6 speed gearbox.
    I sorted the poor radio reception. I googled "Audi A4 Cabriolet radio signal reception" and read the various threads that came up. They all suggested the wires in the left hand side (nearside) rubber gaiter from the car to the bootlid do break over time and that was my problem.
    I ended up replacing an 8inch length of the black radio wire with the "beige" connector onto the left hand side amplifier (the connector is the first one on the left). The Audi cable is extremely thin, not like old fashioned coaxial cable and it was difficult to strip the audi wire back to expose the inner core and the very thin white insulation between the inner core and the outer shielding wires. I soldered in just normal automotive wire to replace the inner core, used heat-shrink to insulate the inner core and the soldered joints to the white insulation. I then used copper shielding from some domestic coaxial cable to go over the insulated inner core and join to the existing shielding in the remaining audi cable. Then a larger diameter heat shrink over that and the wires were fed back though the rubber gaiter and back into the bootlid and connected up.
    The radio now works fine I'm pleased to say.
    Total cost.....zero as all the bits I used I had lying around. It took about an hour and a half to fix. Not difficult just a bit daunting...
