Poor Performance
MingBluS3 Jan 5, 2004
  1. MingBluS3
    MingBluS3 Member
    360
    Where can i get my boost pressure checked and engine? I dont think Audi have the correct equipment.
    It's still under warranty and i'm sure it's got a power leak has anyone got any ideas.
    Also are there any things i can suggest Audi checks. Plus my s3 is doing 1 litre of oil every 1000 miles and Audi say that is fine. It's got 36,000 on the clock.
    thanks
  2. AlexStanley
    AlexStanley Member
    621
    How far away from AmD are you? They're pretty knowledgeable...
  3. MingBluS3
    MingBluS3 Member
    360
    I'm in Essex and they are up the M40, too many mile to get it checked. Audi need to do something about it, i was thinking about calling Audi Roadside.
    Is the oil consumption normal.?
  4. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Essex to AmD - that ain't far!
    Aberdeen to AmD... now that's is a journey! Worthwhile though! (if only I had more money!)
  5. MingBluS3
    MingBluS3 Member
    360
    It's enough seeing as i've been doing 1000 per week for the last year. I've just parked it round my nans. How can Audi sell Turbos when they don;t have the tools to check them?
  6. AlexStanley
    AlexStanley Member
    621
    Mine uses about 2 litres between services, so that's roughly 1 litre every 9000 miles or so at a guess.. I've certainly never seen 1 litre per 1000 miles in my car...
    What about other people?
  7. MingBluS3
    MingBluS3 Member
    360
    Well I've never had a car use so much oil, plus there are no signs of any leaks.
    I've mentioned this to Audi on a few occasions and the last time i menitoned it the Technician said that the car will use more oil while its running in.. Its done 36,000 miles.
  8. Drill
    Drill Member
    928
    What about the MAF?? My German dealer has said that there is a Technical Bulletin out on S3/TT MAF's, so it might be worth looking into /ubbthreads/images/graemlins/crazy.gif
    /ubbthreads/images/graemlins/beerchug.gif
  9. MingBluS3
    MingBluS3 Member
    360
    MAF, I'm not sure what this does?
  10. phillj
    phillj Member
    79
    [ QUOTE ]
    [/ QUOTE ]
    The MAF regulates the intake air flow and is located just after the air box. There is sensor in there regulating how much air is going past it.
  11. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Here's a link on how to clean it, if that helps:
    http://www.audi-sport.net/ubbthreads/showflat.php?Cat=1,10,15,105,200,900,1000&Board=a3s3&Number=43000&Forum=a3s3&Words=maf&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=42873&Search=true#Post43000
  12. MingBluS3
    MingBluS3 Member
    360
    Nice one Chaps...
    I'll have a look tonight if there is enough light.
  13. nice one, those guys at PTS are brilliant, they have worked their magic on my audi several times. What did they say?
