Poly snub mount options..
Jason.s Apr 6, 2011
  1. Jason.s
    Jason.s Active Member
    2,879
    348
    Phoned up Awesome and they dont have any of the old APR mounts anymore and they were pretty sure that the Neuspeed one for the B6 doesnt fit due to different shaped holes. I`d like one before i get my cambelt/clutch/fly done which hopefully should be soon so getting one from America is effort and takes too long.
    Anyone ever made their own?
    I also wondered what the RS4 one would be like, if it was any harder and so on. On ETKA it lists it as the same as the 6 cylinder Passat Diesels engines so have ordered a standard one for the A4 and an RS4/Passat diesel to compare. If its beefier and roughly the correct internal diameter then i`ll use that but if not then its back to the drawing board.
  2. aragorn
    18,665
    880
    Neuspeed one fits fine.
    The hole is a different shape, but it goes on all the same.
    Had one on the old FWD but it went with the car. Perhaps i should go steal it back, mums never going to notice the difference :p
  3. Jason.s
    2,879
    348
    haha well thats alright then. Will see what this one i`ve ordered in looks like. If its pap and looks like it`ll do no better than standard one then i`ll order Neuspeed one. Far too much movement in the gearstick when accelerating and letting off even with brand new engine and gearbox mounts.
  4. aragorn
    18,665
    880
    Did you uprate the engine and tranny mounts when you replaced them?
    I've got a pair of used S4 ones to go on shed, and they're much stiffer than the ones i removed!
  5. jcb
    jcb Active Member
    4,132
    13
    now there is a quote for life!!
  6. Jason.s
    2,879
    348
    I was going to order RS4 mounts but didnt have 150quid(COST) to spend at the time plus i couldnt be ***** to order from Audi so i got brand new standard ones for nothing including gearbox mounts to which i found when i changed the n/s gb mount it had detatched itself from the metal housing and was near enough hanging out lol. Made it all a lot better but still not enough for my liking. The standard snub mounting is pretty useless. Squishy useless piece of foamy rubber so hopefully this different one i`ve ordered is better as it`ll only cost me a few quid at cost.
  7. aragorn
    18,665
    880
    yep.
    I took my tranny mounts off the shed while its engine is out and i've filled them with polyurethane sealant. Did the same with the rear diff mount. Unfortunately the engine mounts are fluid filled and theres no void to fill will sealant so they'll be going on as they are.
    Will probably get a neuspeed snub, as they're pretty cheap.
  8. Jason.s
    2,879
    348
    Yeah thats what i did lol.
    Neuspeed one is pretty cheap indeed. £31 odd with delivery and on ebay from Awesome atm. Im pretty sure the old APR ones were more and they didnt look as good as they were the same as the standard ones but poly instead so wouldnt squish. Neuspeed shouldnt really move all that much at all which is good. Will know by friday if i need to order one if this RS4 one is useless
  9. AndyC
    AndyC Moderator Moderator
    719
    got one from 034 with the new housing as well... seems to be good.
    I am getting some harder mounts made for tranny and engine over the next few weeks.
  10. Foxmeister
    Foxmeister Fired Up!
    1,785
    Link to Neuspeed mount please?
  11. yavuzongul
    yavuzongul New Member
    10
    Can u tell me the feelings ?
    how do they effect the comfort and performance ?
  12. Jason.s
    2,879
    348
  13. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    You happy with those mounts Kev? Told you they were in good nick!
    I bought the 034 track density engine mounts. They are solid, but I compared them next to the stock mounts and there is a void on the stock ones which could be filled with something like Tigerseal. It's like a ring around the top of the mount.
    Anyone know if the 1.8T and S4 snub mounts are the same? If so, I can measure my JHM snub mount when I get home for you.
  14. Jason.s
    2,879
    348
    Yeah its the same. Its only the 2.5 diesels and RS4 mounts that are different to the rest.
  15. aragorn
    18,665
    880
    Scott: Aye mate they're spot on, nice and tight unlike the snapped ones i removed.
  16. Jason.s
    2,879
    348
    RS4 mount it is :happy:
    You can squash the standard one so the hole in the middle is almost closed together with one hand. Try doing it with the RS4 mount and its solid! it doesnt compress even 1mm unless you use 2 hands and really squeeze it and even then its a struggle. That`ll be going on when the rest of the work gets done.
    Its only £10.68 inc vat so should be a nice cheap way of reducing movement.
  17. Blue_Thunder
    1,778
    33
    Anyone want my S4 one before it goes in the bin? That's solid rubber as well.
  18. aragorn
    18,665
    880
    go on then, so long as its nice and stiff like jason says the RS4 one is ;)
  19. Foxmeister
    1,785
    Does the mount for 1.8 do mine aswell?(2.8 v6 Quattro)
    Or is the RS4 one just as good, and cheaper alternative??? Is it fitted and tested yet?
  20. Jason.s
    2,879
    348
    Will be fitted and tested hopefully in the next month when all my work eventually gets done. yours will be pretty much same as the 1.8t im sure but cant be 100% without looking at work.
    RS4/2.5 diesel is the best OEM option and is only a tenner
  21. jamie226bhp
    jamie226bhp Member
    468
    Any one got the part numbers of these mounts as I'd like to change all mine on my 2000 1.8 tqs
  22. Jason.s
    2,879
    348
    Which ones you after? standard ones or better OEM mounts? like RS4 or something?
  23. jamie226bhp
    jamie226bhp Member
    468
    All of them gradually for Better oem ones as long as they don't break the bank
  24. Jason.s
    2,879
    348
    Left, right and snub RS4 mounts including the vat comes to £217.68. Gearbox mounts you`d be better off doing as Aragorn did and fill them with tigerseal to stiffen them up
    left and right is 8D019979AD and snub is 8D099339E
  25. jamie226bhp
    jamie226bhp Member
    468
    Is it a genuine Audi only item or are gsf ones ok
  26. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    i dont think the rs4 snub will be a tight enough fit in the mount to make that much difference, plus its rubber so will deteriorate
    the neuspeed one you have to ignore b6 fitting instructions and turn through 90deg then its a very tight fit in the b5 mount (it probably works better in a b5 than a b6)
  27. aragorn
    18,665
    880
    Its not really supposed to be a tight fit, as if it is it transmits huge amounts of vibrations into the car.
    The idea is that when the engines "at rest" the snub sits centralised in the housing but not touching it. When you load it up the engine naturally tries to lift and the snub then comes up against the housing stopping it moving any further. Ideally you want a very small airgap of no more than a milimeter or two, and with a stiff mount this typically works fine, giving a decent balance between comfort and performance.
  28. Jason.s
    2,879
    348
    Yeah pretty much^
    If i wanted it solid then sure but my ex had pretty much solid engine mounts in her Celica GT4. Sure it was a track car but jesus the vibrations were shocking and you could watch the bonnet vibrate more than having a huge sound system.
  29. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Just to resurrect this thread for a min... Was the definitive answer for a snub mount upgrade the RS4 item pn 8D099339E ?
    Got to do the belts at some point this summer and thought I might as well do the snub too :)
  30. aragorn
    18,665
    880
    Its 8D0199339E!
  31. NineNails
    593
    Well spotted Kev cheers!
  32. Foxmeister
    1,785
    Geeman has one for sale, ad is on SRS but hes on here aswell, maybe pm him?
  33. NineNails
    593
    Cool, cheers. I'll shoot him a PM
  34. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    As the V6/RS4 snub mount is the cheapest to replace I'm planning on starting with this one...
    Can the part be fitted without moving the engine or pulling front end of car out?
