Pollen Filter
Kevint Jul 16, 2005
  1. Kevint
    Kevint Active Member
    1,182
    Where is it and how do you get to it?
    I've got a leak every now and then into the passenger footwell, general opinion is a bloked drain under/in the pollen filter housing.
    I assumed it's to the rear of the engine compartment under the plastic scuttle plate thing /ubbthreads/images/graemlins/confused.gif
    I took the first part off (that covers the batter and water resevoir) the undid a small headed screw to try and take another part out but stopped at this point as I could not see the filter housing.
    Am I in the right place?
    Kev.
  2. Kevint
    1,182
    [ QUOTE ]
    remove battery cove remove bottom windscreen cover three phillips twist screws and one 8mm bolt and put wipers n up postiion and take out the clip in the middle holding the two scuttle pannels together remove the passengers side one and bobs your uncle
    [/ QUOTE ]
    Should have searched first I suppose /ubbthreads/images/graemlins/book.gif
    Kev.
  3. Danielson
    Danielson Member
    704
    hi i found under the battery there was a couple of grommets which were full of ****, so the water couldnt escape, worth looking.
  4. Kevint
    1,182
    Cheers snoop,
    I'm going to try and take it all apart again tomorrow.
    Kev.
  5. kilcoo316
    kilcoo316 New Member
    10
    Did this leak come in the footwell beside the centre console?
    Think I might have the same problem.
    What did you do to sort it? Change the pollen filter?
  6. dsts
    dsts New Member
    Hi,
