Pollen filter! Where is it?
selector007 May 19, 2008
  1. selector007
    selector007 Member
    47
    A3, 2000, 1.8T Quattro.
    I've searched the forum for threads on this but cannot find my answer. Can anyone put
    me in the right direction to finding the pollen filter? What does it look like? And how do i change it?
    I have managed to change the air, oil filters and the spark plugs so i thought i would give the pollen filter a go, well if i can find it!?
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    passenger side, under the scuttle panel.
  3. selector007
    selector007 Member
    47
    Where is the scuttle panel? In or outside the car?!
  4. simch
    simch Active Member
    2,028
    er...on the end of that great big red arrow!! lol
  5. selector007
    selector007 Member
    47
    Yep so it is!!! Thanks for pic! must have sent that message at the same time i sent mine!
  6. Clach
    Clach A3 - 1.8Ts
    971
    That is a very shiny engine you have there adbus....
  7. abdus
    1,827
    that was a quick clean when I first got it...it was more like this:
  8. Clach
    Clach A3 - 1.8Ts
    971
    Any tips, other than elbow grease?
  9. abdus
    1,827
    warm engine, apply tetroclean engine degreaser with a brush, leave for 4-5 mins. Start engine and jet wash (don't stay long on any area).
    Leave engine to run for 15-20 mins to allow all water to dry. THen spray some rubber/vinyl care and wipe any overspray ;)
  10. Clach
    Clach A3 - 1.8Ts
    971
    roger...
  11. Shy19s
    Shy19s Oil running through my veins.
    886
    When jet washing or steam cleaning engine bay you should cover your dizzy cap with a plastic carrier bag, also other exposed sensors, sometimes found around the injectors etc and obviously if you have an induction kit, id cover that too..id also spray some sort of WD40 or a simular product over the block to stop it from oxidising after the jetwash. if you have a leaf blower you can quicken the drying process by blasting the excess water off the engine, you can always use those Vax blowing hoovers too.
  12. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    Cue loads of S3 owners wasting an hour looking for their distributer cap, bwahahahaha.
    Shy - Is your A3 from the 1980s?
    Dizzy cap indeed :)
  13. fingermouse
    fingermouse thats me
    4,009
    be warning of the coil and HT lead next ,
    even checking the points gap ..................
  14. rickparmar
    rickparmar Active Member
    2,322
    13
    how do you change the pollen filter ?, ive tried but i cant get into it
  15. rickparmar
    2,322
    13
    ignore me, that was the easiest thing to do
  16. Ess_Three
    Ess_Three Active Member
    5,383
    I never do.
    My engine bay isn't sealed, nor is it waterproof...so in Scotland **** gets wet...so I don't doubt the effectiveness of the electrical connectors seals.
    All I do is spray on de-greaser, brush it in, leave it to soak and hose off.
    I'd never use a jetwash...low pressure, high volume will shift the crud.
    Then just start it to help dry it all off.
